Engine Drop
Am dropping 1985 Carrera engine to replace a number of parts for general maintenance. I’ll list these parts below.
If you have any suggestions as to what I should look at and what I should do while the engine is out, I’d welcome your input. I was going to replace all the oil seals but have grown fond of adding 2-3 quarts monthly and changing the filter every other month. No leaks are over the manifolds. I drive under 1,000 miles per month. I'm planning to dump the sump and tank once a year. I've been checking the oil consistently, placing a few hot drops from the stick on a sheet of brilliant white, glossy paper. It's very clean. (Cannot say the same for garage floor.) Replacing:
Notes: Engine has turbo valve covers and collapsible return tubes. Valve clearance was set a few months ago. Flywheel sensor, cylinder head temp sensor, starter, distrib cap & rotor, ignition wires were recently replaced. Blistering/cracking fan: ![]()
You have a pretty good list. I say replace the internal oil thermostat while you have the engine out too. Mine was stuck open.
Rear main seal, any external seals and gaskets that are hard/impossible to get to with the engine in..
Gary R. |
How many miles on the engine? If over 100,000 check for head stud (lower) breakage and possible valve guides and valve grind.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Thanks guys ~
Engine has 230,000 miles. |
French Import
I am going through a similar maintenance and would suggest the following:
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
2-3 qts for each 1000 miles, 230K on a 3.2, your valve guides are most likely toast. You should plan on a top end rebuild at the least.
Gary R. |
Member 911 Anonymous
Synthetic Gear Lube? Are you sure?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Vaccum lines
Replace the vacuum, and fuel lines:
![]() Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Positive, nothing is better in the 901.6
Gary R. |
AutoBahned
my suggestion is to do a search on engine drop and you will find many ideas
a 1985 trans. will be a 915 - so do NOT put a synthetic gear oil in it; use Swepco I dunno how the above opinion was arrived at but it conflicts with everything else |
Relax RW, I was just playing off Draco's out-of-nowhere comment.. no such thing as a "901.6" as far as I know!
And I say use Kendall in a 915!
Gary R. |
Synthetic Trans Oil
A mechanic (Richard Danvers) that used to work on the car put the synthetic in when I first got the engine at 62,000 miles. (It's in a 1980 Targa. At the time I had the option to rebuild my existing '80 engine or get the 85 Carerra -- I chose the latter.)
I wast told that once synthetic has been run in a trans, it's not good to put fossil oil in afterwards --- stay with synthetic. |
^this is very exciting!!!
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
Gary R. |
Either way change the gear lube after 1000 miles to get most of the synthetic out.
