Where to put temperature probe?
I just bought a digital temperature monitor from Radio Shack so I could tell how hot it was outside. But the problem is, where should I locate the probe to get the best reading?
I was looking through my manual on my Caravan to get some idea where Dodge puts it but it doesn't go into that detail, so I leave it to the board for the answer. Oh yeah, forgot to mention it's going in the Carrera...of course! Cheers, Joe 86 Carrera 92 Grand Caravan 86 Olds 98 |
You do not have permissi
That is a tough one. In the engine compartment=heat. In the cab=heat multiplication. Under the front end=probably most accurate but wind chill when moving.
Digital temperature probe?
Umm.... first get on your stomach..... make sure your shorts are to your ankles..... and..... No mom ...I'm not sick anymore...really! |
MOST AUTO MANUFACTURERS PUT THEM IN FRONT OF THE A/C CONDENSORS OR ATTACHED TO THE FRONT BUMPER ON THE INSIDE. JUST PUT IT IN FRONT AND OUT OF THE SUNLIGHT. ALSO WINDCHILL IS NOT A FACTOR UNLESS YOUR PROBE HAS SKIN AND A HEARTBEAT .
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
Thanks for all the help, I knew I could count on you guys for the answer.
I think I'll tape it somewhere behind my front valance, probably by one of my fog lights. Cheers, Joe |
You should keep your probe dry (in this case). A wet probe will experience wind chill (evaporation).
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Behind the front bumper is ideal.
