engine drop question
Hi guys getting ready to do the first time dreaded engine drop to replace
my front and rear seals. And whatever other oil leaks I can find. Do you really need to drop both the engine and transmission together or is it just as easy to drop just the engine and leave the transmission in place. It's a 73T 2.4 with a 901 transmission. Thanks in advance. Mike |
1988 Carrera
Engine and trans together is the way to go. Trying to get just the engine out is a PTA.
ROW '78 911 Targa
+1, I'm sure most others will say the same.
engine drop
drop em together.
For Sure Together. We know the Wayne's 101 book says engine only, but that was just his best idea when he wrote that book. The best collective advice now is yes, drop both together as one unit, then separate, if necessary when out on your dolly. It's fun! Do it!
And remember to post the required picture!
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
Thanks guys was thinking that just the one piece would be smaller and
seemed as it may me easier to handle but will take a look at both together. Thanks Mike |
Thanks Scot it was Waynes book that I was reading and yes I will post
the "required" picture. |
Sugar Scoops Rule :)
So why does the 101 book show the engine only?
Dave _______________________________________________ '76 911S Targa '62 VW Type 1 Sunroof '73 914 2.0 (1st Porsche, gone long ago but not forgotton) |
I've dropped and raised these at least 40 times, and together is the way to go.
Current: 914/6 GT Conversion, Cayman Old: Many PCars + Formula Racecars |
Jaybird12
Hi Mike. When I dropped my 2.7L with a 915 for the first time it was relatively easy to take them out as one unit. I had a hoist and a floor jack with a transmission cradle.
Jason 1975 Euro Spec 911S Targa 1987 VW Westfalia Camper 2006 Subaru Forester |
Hi Jaybird12 I don't, have a hoist but I do have jack stands and a couple floor jacks
So I thought I would attach some blocks of wood to a piece of 3/4" ply wood and Some dolly wheels and make a platform with those. |
Diss Member
Get a cheap skateboard and cut the kicktail off of it. Screwing a couple blocks to it on either side of the center rib helps too.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Not to mention, they come out more balanced as a set. The balance point is at the bell housing.
Michael PCA-INWR 356 Reg. Early S Reg. R Gruppe PNW |
Its really simple ..i did it the first time in my 88 two weekends ago after about 2 hours unhooking things, the actual drop took 30 minutes.... A big flr jack, bunch of wood blocks and a 15 dollar furntiure dolly from hf is all you need ...the trans connected balances out the engine weight and greatly simplifies the operation. Soak the trans and engine mt bolts in pb blaster o. N. . Be sure to completely unhook the shifter from the trans!! Good luck frank
Pulling the engine only is easy...but when reinstalling...try to get the throw out bearing and the cases lined up with no room to see...and your hand jambed into the most difficult space you can imagine.
Out as a pair...in as a pair. Bob
Bob Hutson |
Jaybird12
Good luck. It's certainly doable.
I recall Wayne posting something about having (or having heard of) stripped CV joint bolt heads and the problems that could cause.
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...." -- William Faulkner |
Harbor Freight always has dollies on sale. Attach some plywood to one of those. Shawn
Member 911 Anonymous
Or even softer Pine planks, they are much softer and gentler to the case. I love using the HF motor cycle jack, very stable wide base. the lock is a bonus when propped up.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks for all the suggestions guys I like the skate board idea and I think I may have
An old one of my son's in the crawl space. Do you raise the front wheels off the floor as well to keep the car a bit level or just raise The rear and block the front wheels? Thanks Mike |
