engine drop question
Hi guys getting ready to do the first time dreaded engine drop to replace
my front and rear seals. And whatever other oil leaks I can find.
Do you really need to drop both the engine and transmission together
or is it just as easy to drop just the engine and leave the transmission
in place. It's a 73T 2.4 with a 901 transmission.
Thanks in advance.
Mike
Old 11-30-2012, 01:24 PM
1988 Carrera
shadowjack1's Avatar
Engine and trans together is the way to go. Trying to get just the engine out is a PTA.
Old 11-30-2012, 01:31 PM
ROW '78 911 Targa
timmy2's Avatar
+1, I'm sure most others will say the same.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-30-2012, 01:37 PM
noavgdrvr's Avatar
engine drop
drop em together.
Old 11-30-2012, 01:39 PM
scotricker's Avatar
For Sure Together. We know the Wayne's 101 book says engine only, but that was just his best idea when he wrote that book. The best collective advice now is yes, drop both together as one unit, then separate, if necessary when out on your dolly. It's fun! Do it!
And remember to post the required picture!
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 11-30-2012, 01:41 PM
Thanks guys was thinking that just the one piece would be smaller and
seemed as it may me easier to handle but will take a look at both together.
Mike
Thanks Scot it was Waynes book that I was reading and yes I will post
the "required" picture.
Old 11-30-2012, 01:44 PM
Sugar Scoops Rule :)
dave 911's Avatar
So why does the 101 book show the engine only?
Dave
_______________________________________________
'76 911S Targa
'62 VW Type 1 Sunroof
'73 914 2.0 (1st Porsche, gone long ago but not forgotton)
Old 11-30-2012, 02:32 PM
I've dropped and raised these at least 40 times, and together is the way to go.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 11-30-2012, 02:55 PM
Jaybird12
Jaybird12's Avatar
Hi Mike. When I dropped my 2.7L with a 915 for the first time it was relatively easy to take them out as one unit. I had a hoist and a floor jack with a transmission cradle.
Jason
1975 Euro Spec 911S Targa
1987 VW Westfalia Camper
2006 Subaru Forester
Old 11-30-2012, 03:22 PM
Hi Jaybird12 I don't, have a hoist but I do have jack stands and a couple floor jacks
So I thought I would attach some blocks of wood to a piece of 3/4" ply wood and
Some dolly wheels and make a platform with those.
Old 11-30-2012, 03:53 PM
Diss Member
Quicksilver's Avatar
Mike
Get a cheap skateboard and cut the kicktail off of it. Screwing a couple blocks to it on either side of the center rib helps too.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-30-2012, 03:59 PM
mjmoran's Avatar
Not to mention, they come out more balanced as a set. The balance point is at the bell housing.
Michael
PCA-INWR
356 Reg.
Early S Reg.
R Gruppe PNW
Old 11-30-2012, 05:08 PM
Its really simple ..i did it the first time in my 88 two weekends ago after about 2 hours unhooking things, the actual drop took 30 minutes.... A big flr jack, bunch of wood blocks and a 15 dollar furntiure dolly from hf is all you need ...the trans connected balances out the engine weight and greatly simplifies the operation. Soak the trans and engine mt bolts in pb blaster o. N. . Be sure to completely unhook the shifter from the trans!! Good luck frank
Old 11-30-2012, 05:46 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Pulling the engine only is easy...but when reinstalling...try to get the throw out bearing and the cases lined up with no room to see...and your hand jambed into the most difficult space you can imagine.
Out as a pair...in as a pair.
Bob
Bob Hutson
Old 11-30-2012, 10:47 PM
Jaybird12
Jaybird12's Avatar
Get those jack stands as high as you can and take off the rear valence to get as much clearance as you can. It's certainly a two maybe three man job for your first time. Make sure one guy is watching the shifter linkage so it doesn't get hung up. You'll ruin the seal on the tranny if you put much weight on the shaft that sticks out. Ask me how I know!
Good luck. It's certainly doable.
Jason
Old 12-01-2012, 02:47 AM
NOLAsc's Avatar
I recall Wayne posting something about having (or having heard of) stripped CV joint bolt heads and the problems that could cause.
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...."
-- William Faulkner
Old 12-01-2012, 04:09 AM
NOLAsc's Avatar
I like prepping the engine/tranny for removal -- all the way to the four bolts -- and then lowering the car as much as possible while still being able reach the tranny bolts. That way you don't have to lower the engine so far. Once it is free, I jack up the car again. I didn't have to remove the valence or bumper, but a friend always does on his car.
Harbor Freight always has dollies on sale. Attach some plywood to one of those.
Shawn
-- William Faulkner
Old 12-01-2012, 04:16 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Or even softer Pine planks, they are much softer and gentler to the case. I love using the HF motor cycle jack, very stable wide base. the lock is a bonus when propped up.
'85 Carrera Targa
PCA/POC
Old 12-01-2012, 07:53 AM
Thanks for all the suggestions guys I like the skate board idea and I think I may have
An old one of my son's in the crawl space.
Do you raise the front wheels off the floor as well to keep the car a bit level or just raise
The rear and block the front wheels?
Mike
Old 12-01-2012, 12:42 PM
