Another Engine Drop Question
Hi guys just wondering if when preparing for the engine drop does
anyone cut there alternator wires in the engine bay area and splice
in wire connectors or a plug of some type rather than tearing the fan
ass'y apart to get at the wires.
Mike
Old 12-06-2012, 01:47 PM
schumicat's Avatar
not sure why you'd do either of those things. you just unscrew a nut and the wires come off.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 12-06-2012, 02:28 PM
Champagne on Beer Budget
HelmetHead's Avatar
Why not just unplug the 14pin connector on the rear fuse panel...engine comes out with harness...?
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 12-06-2012, 02:34 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Mike
The alternator stay with the engine when you drop it (along with the transmission).
There is only a few plug to take apart, definitely nothing to cut.
Are you around Ottawa?
Who Will Live... Will See
Old 12-06-2012, 02:42 PM
You have a 73 911T, there are very few connectors to disconnect during an engine drop. None of them is the Alternator wires.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-06-2012, 03:21 PM
@ the voltage reg on a 73, just un plugs
Bruce
Old 12-06-2012, 03:26 PM
Thanks guys I'm glad I posted this question because the Haynes manual say's
to mark and then disconnect the leads from the alternator and in order to do that
you have to gently unscrew and slide the fan ass'y forward enough to remove the
plastic air deflector in order to access the nuts holding the wires on.
Anyway I assumed the wire harness went down the rear firewall and through
the tunnel to the fuse box by the battery.
After reading your replies I just went and crawled under the car and I see that
it only goes to the starter and transmission area.
Glad I did not start cutting wires first.
JJ911sc no I wish I lived closer but I am in the Trenton area.
Thanks for your help guys sure you'll here from me again once I get started.
Mike
Old 12-06-2012, 04:20 PM
JJ 911SC's Avatar
Mike
The description from the Haynes in your post is basically if you need to remove/replace the alternator or to remove the plastic shroud as the harness goes through the shroud.
Remember to take lot of pictures and notes of every steps you do because when its time to put it back... it can be a few months down the road.
Also never a dumb questions for this site. I have a computer in the garage and when I ran into problem I post and get reply within minutes.
Take your time and if it get frustrating, have a beer and sleep on it.
Have fun
JJ
Old 12-06-2012, 04:57 PM
Oh, that manual. I use that as a jack pad.
Old 12-06-2012, 05:48 PM
ROW '78 911 Targa
timmy2's Avatar
One came with my car, no wonder it wouldn't run....
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-06-2012, 06:45 PM
