Indentification of part?
Hello, Newby question. Can you please tell me what this part is the the black circle is around. There is a rubber boot around the wire connector and it has seen better days.
1978 RUF 911SCR |
That's the thermal time switch. It regulates current to some cold start devices, including the cold start valve by opening when the engine begins to warm and breaking the ground circuit.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Do you think it is possible this could cause a hesitation if it were to get wet when its raining hard?
1978 RUF 911SCR |
No, will not cause hesitation.
Howard
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
raining hard....check for water in your dist cap
ask me why :banghead:
Ed M 86' Coupe |
Most people say to remove cap and put some Vaseline around the lip
Justin 84 Carrera Targa 98 F-150 4x4 |
Beat me
Ok thanks. Just eliminating possibilities. The rubber boot over the connectors is toast, is it worth replacing?
1978 RUF 911SCR |
Thread Tools | |
Rate This Thread | |
