engine compartment light help
how does it switch on? opening the hatch? opening the trunk? is there a switch?
its a 1984 euro 930 thanks!!!
1984 ROW 930 turbo with rarly8 exhaust, waste gate pipe and HEADERS K27HFS TURBO, B&B IC, 1 bar spring,LEASK WUR with rpm solenoid, fab speed intake filter, front strut brace rennline. MOMO wheel, Innovative afr 16-1 gauge, custom 930 ELGIN cam |
On my 89 Carrera Coupe, there is a rotating cover (over the bulb) that actuates contacts, allowing the light to come on. When you close the bulb cover, light goes out.
BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
thanks! ill chech and try and see
check
I'm not 100% sure but I think you need to turn on the parking lights and open the cover.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Engine Compartment Light.
Yes-for our '86.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Yes! Thanks everyone! It works! Parking lights on then flip the metal cover and ON!!
Recreational Mechanic
Parking or headlights must be on. Rotate the chrome cover open on the light and it should come on.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Senior Advisor
ok, banged that problem out, what's next?
08 Cayenne Turbo |
Getting heater hoses to and from heat exchangers and replacing the aux footwell fans(which i got used) to see if that works. Also not sure if my reverse lights work so going to check that too and see where the problem is... Prolly the tranny switch or hopefully just cleaning out connections!
Senior Advisor
there is a pin in the transmission that pops out and makes the contact to the reverse switch, make sure that is working. Some great tips in search, of course after verifying there is power to the switch and the bulbs and the grounds are good. heater hoses are a pain, really need a lift for them.
08 Cayenne Turbo |
Go-Kart Mozart
-J |
Excellent. Ill check the tips on making the reverse light work!
Ok, with the parking Lights on and chrome cover open I still have no light in engine compartment. Bulb checks good when out of car with a meter. Would there be a fuse in the loop that has gone bad? would the parking lights still work? 1987 Carrera Coupe.
Is there a wiring diagram on site for 1987 model Porsches Last edited by DRONE; 10-15-2013 at 08:12 PM.. |
bump
muck-raker
Drone,
I'm not an expert but I'll chime in with my limited experience. The engine compartment lamp is tied in with the front and rear parking lamps on the driver's (left hand) side of our cars. Do yours currently work? If so, you'll need to diagnose some stuff. First, check for burnt fuses up front (I don't know which one). If the fuses check out OK, I would check the wiring to the lamp itself because these units are subject to a lot of engine heat. Second, check the lamp itself for the same reason I previously mentioned...mine was toast. I wound up purchasing a new one, problem solved. Good luck.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Driver, not Mechanic
Mine is an 88 911 and does not require that the parking lights are on. What it does need is some jiggling of the wires to the switch. I think I need to sand down the contacts more as there might be paint preventing good contact after the reprint.
Parking lights do work so I'll get the meter out and see if I have power to the contacts and work back from there
Thanks for the help I'll report back with progress and if I get it to work I guess I'll be the new SME (Subject Matter Expert)
Removed the fixture and took some scotch brite to all the contact surfaces and the crome cover along with the contacts on the bulb upon reinstallation it works like new
