Dropping 3.2 G50. What to do while "in there"
I'm dropping my engine to do the fuel lines. pelican recommends a replacing a few seals while access is easy. What else should I consider while the engine is down?
'69 911E Targa '87 Carerra Coupe |
AutoBahned
get rid of the G-50 - it is heavy and shifts too fast - this deprives you of the true Porsche experience that a 915 approximates
AutoBahned
also clean the engine esp. the tops of the fins & check the sound pad for integrity; consider replacing rear susp. bushings
check shift coupler |
You trying to be funny, Randy ?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
and the fuel lines if they haven't been replaced. Second on bushings, much easier to get to with engine/transmission out.
Update the clutch fork shaft bushings if they have not been done. Check rear main seal and gearbox main shaft seal.
gearhead
I am looking for the same like button.
Howard
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
updated tube and throw out bearing,
already mentioned - fork bushing kit if you have a rubber clutch, replace with steel spring type replace senders at the front of the engine consider replacing 3rd cyl temp. sensor, if it is old
Sold: 1989 3.2 coupe, 112k miles |
forgot to mention,
I'm interested in the details of what you do on the fuel lines. We've been unable to get Mr. Hippy to respond and are looking for another source.
What?
This is what happened to my car "while I was in there" replacing the clutch.
Doh!
________________________________________ Eric Hahl 85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD) 2015 981 Cayman S (Sold) 23 Outback Wilderness & 23 BMW R1250GS |
AutoBahned
BoxsterGT can make fuel lines - may be on vacation during the holidayz
Diss Member
Check all the rubber hoses for cracks and hardening. I discovered that the fairly hard breather lines are actually supposed to be pretty soft when the end of one cracked off while trying to reattach it. The only time replacing them will be easy is when the engine is out.
You can get the fuel hoses replaced at any competent hydraulic hose shop. I carried my hoses into Mesa Hose in Costa Mesa and the guy behind the counter glanced at me standing behind the guy he was helping and said, "Porsche fuel hoses. Throw them in this bin." I guess he has seen a few... ![]() For the fuel hoses the normal route is to have them replaced with stainless braid but the smart money is on stainless braid with an outer rubber sheath. Doesn't look as cool but bare stainless braid is like a saw blade and will abrade through most anything. If the engine hasn't been running rock solid smooth you might go and replace the intake manifold gaskets. (There are 12.) If you do that you will also want to replace the plastic spacers as they are hardened and will certainly crumble when you try and clean them.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Quality stuff from BoxterGT, for sure!
BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
BoxterGT Fuel hose set for G50 3.2!
I have a brand new, never opened set of fuel hoses that Boxster Len made me last year ..never used them while waiting to drop my engine. now that i have it out i am switching to ITBs so i will not need the hoses Email me if interested: rauscher@wistar.org. Cheers Frank
The Dude abides...
Steve '03 Carrera 4S |
