LinkBack Thread Tools Rating: Thread Rating: 19 votes, 4.26 average.
Cory M's Avatar
Got a new project. Today I flushed the brakes, adjusted the ride height, and swapped the wheels for some Fuchs with Toyo R888's. I also ditched the sugar scoops for some H4's. still need to figure out the headlights because they are flickering between brights and lo beams, and the low beams are weak.
Before
After
Old 12-27-2016, 07:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6021 (permalink)
Before
After
Looks amazing! Great job man. What size tires are those.
Old 12-27-2016, 07:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6022 (permalink)
Cory M's Avatar
Thanks, the pictures hide a lot of flaws! They are 225 front, 245 rear, on 16*7&8" wheels.
Old 12-27-2016, 07:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6023 (permalink)
Carmagic.us
rothaus's Avatar
The car looks great with the black Fuchs and the H4.
The headlight issue could be fixed with a set of headlight relay.
Cheers
Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 12-28-2016, 03:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6024 (permalink)
Cheers
Engelbert
Agree. Also could be in the steering column dimming switch.
Car looks great.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 12-28-2016, 05:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6025 (permalink)
RETIRED
Joe Bob's Avatar
Sometimes the stalk can be mended (tabs/contacts re-bent) or cleaned instead of replacing. There are more than a few threads on the matter.
2012 ML350 3.0 Turbo Diesel
Old 12-28-2016, 06:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6026 (permalink)
sugarwood's Avatar
Replacing the turn signal stalk might be an option.
JoeBob, I sent out the notebook and money clip. Enjoy!
1986 Bosch Icon Wipers coupe.
Old 12-28-2016, 07:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6027 (permalink)
nameisbauer's Avatar
Send a message via AIM to nameisbauer
What joe bob said, search before you buy anything, I just bent my contact back
with a screwdriver. Great looking car.
Jim
911 Mint Green "RSC" #mintgrun
911 Gentlemen's Rallye 85 Carrera GP White
2012 C63 AMG Mars Red
Old 12-28-2016, 08:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6028 (permalink)
froggert's Avatar
Pic taken a few days ago, but my car finally has heat! Maybe. Still haven't had a chance to try it out yet.
Old 12-28-2016, 08:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6029 (permalink)
spoke's Avatar
...still need to figure out the headlights because they are flickering between brights and lo beams, and the low beams are weak.
I had the same problem with my '86 930 except it wasn't flickering between high and lows, it was just the highs coming on with the lows.
Found a thread here on adjusting the high beam contacts on the turnsignal stalk. Problem solved.
Find Spoke's LED Products:
www.spokeworksled.com
Old 12-28-2016, 09:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6030 (permalink)
spoke's Avatar
Rewired the running lights to be on all the time with the ignition key. It's the red wires going from fuses 4-6 on fuse block 1 to fuses 5 and 6 on fuse block 2.
Next upgrade for this will be to add a relay to keep the light current from the ignition switch.
Old 12-28-2016, 09:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6031 (permalink)
Originally Posted by anglophone1 View Post
Drove Jaffa SC for two hours or so -last drive before Christmas and the salt goes down.
Healy Pass- West Cork- Ireland- Great place to live!
That is gorgeous - Wish it was me.
Do you see many other cars (or any police cars) on this drive?
Will you rent your car? If so, we can do the "Holiday" you can come to NY and stay in my house and drive my cars. Deal?
Old 12-28-2016, 09:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6032 (permalink)
The Dude abides...
bigel's Avatar
Interested in more information on your "running lights" configuration. Have you posted a more extensive description somewhere on the forum?
'87 Targa Granite Green
Old 12-28-2016, 10:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6033 (permalink)
Cory M's Avatar
Thanks for all the advice. I'll check out the contacts.
Old 12-28-2016, 01:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6034 (permalink)
spoke's Avatar
Here's the thread about the high beam contact.
turn signal switch quick fix pictures
Old 12-28-2016, 03:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6035 (permalink)
spoke's Avatar
Here's the thread that I used to re-wire the running lights to be on all the time.
Running/Park Lights On All the Time, and Off with Key
Here's the schematics of what Scot did in the above thread. The schematics are for my '86 930 although re-powering from F3 in Fuse Panel 1 is incorrect for the 930. On the 930 F4-F6 on fuse panel 1 were the ignition-switched power. On Scot's 911, this was F3. I would recommend looking at your car's fuse layout for the switched power. I verified mine with a voltmeter before rewiring.
For safety, ALWAYS remove the negative battery lead before working on the fuse panels.
This is how the car is wired from the factory.
Here's the re-wired running lights running off of the ignition switch instead of the light switch. With this simple mod, you will lose the Euro-Park feature.
Old 12-28-2016, 04:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6036 (permalink)
aualexa2's Avatar
I reinstalled my speedo/odometer after sending it to North Hollywood because the odometer had stopped working. Took it for a short drive to top off the gas, get some milk for my wife, and make sure the odometer worked. The gas station attendant asked me how much he would have to pay me to buy the car. The WaWa (local convenience store) clerk told me my car is his dream car, and a guy in the parking lot asked me what year the car was and then started screaming, "That's so cool! That car is so cool!" Was a good 10 min drive!
Alex
‘73 914 1.7 Phoenix Red
'99 SPB #79
'16 Cayman GT4 GT silver
Gone: '87 911 Blk/blk sunroof coupe, '13 991S Dbm/ag non-sunroof coupe
Old 12-28-2016, 04:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6037 (permalink)
Hi Jerry,
With your LED lights, do you think a relay is needed? Seems like minimal current through the ignition switch.
Thanks,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 12-29-2016, 02:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6038 (permalink)
Pierre911SC's Avatar
Smile
Took out the 3.2ss and getting ready to install a 3.6[img]
http://forums.pelicanparts.com/uploads26/IMG_20161228_14141821483019216.jpg[/img]
Pierre
stsrobotic@yahoo.ca
82 911SC wide body, 3.6L
Old 12-29-2016, 04:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6039 (permalink)
911tracker85's Avatar
trying to pull the O2 sensor to remove the engine tin to do valve adjust.
hoping Louie85 still has / makes them...
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 12-29-2016, 06:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #6040 (permalink)
Tags
fuchs are ugly , stock sucks
