I pulled the horns & bumpers off "Crusty" the 74 911
![]() Does that count?? Thinking this rear bumper will go nicely on my 81. ![]() ![]() ![]() ![]() ![]() ![]()
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Made a new shifter knob and installed it
Carmagic.us
This knob looks great, nice job on the machining.
It would also make a great tap handle, LOL Cheers Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
French Import
A beautiful piece of art, however it would not be usable in the hot Southern California sun... Ouch!
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Finished a 4 month part time project - rewiring most of the systems in the car for simplicity and reliability - using a battery in the smuggler's box, a battery contactor, new main ATO fuse block, three remote fuse blocks and four relays. I am no longer using switches for the main power distribution.
![]() ![]() ![]() ![]() more details here: battery relocate = fuse box relocate? |
Electricity fire and rodent
Installed new battery. Installed fire extinguisher and bracket in front of driver's seat. Removed PO provided, aftermarket rodent.
Replaced the water pump on my C4S. Took me 5 hours! I pulled the engine and trans out of my 72 in less time.
1972 Porsche 911 coupe 2016 McLaren 570S 2016 Cayman GTS 2016 Land Rover LR4 HSE 2013 Mini Cooper S |
The Dude abides...
Great job, Mike.
This is something I'd like very much to do on my '87. Quote:
Steve '87 Targa Granite Green |
Pelican Parts Vendor
I pushed mine out of it's stall so I could fix the hoist. Made a nice change from fixing cars. Then I drove it back in!
Paul Eddleston BRAID Wheels USA Team Illuminata Motorsport |
Carbon fiber hose. nice touch! Do that yourself?
What did you do to your 911 today?
Started this repair last week and it's still rolling forward.
Repaired and adjusted parking brake contact and now the light functions properly. Fixed a short in the auto heat control unit. It should operate too, although I haven't had a chance to cycle it yet. ![]() ![]() While the interior is out, thought I would tackle the broken defroster/fresh air levers. Old broken head unit: ![]() ![]() New/used head unit in place. This is one repair I really don't want to do again.... A major PIA, but doable. Was able to do the repair without pulling the blower. However, I did end up pulling it to reindex the wipers. How's that for ironic? ![]() Although, I have no idea what this mystery white wire is for or even goes too. Haven't found it on the schematic and it just ends in the trunk area. ![]() ![]() The only real challenge was to get my meat hooks in where I could get to the wee 10mm nut for the wiper arm rotation. ![]() ![]() Also cleaned several connections and replaced some bulbs since I was in there. More to follow, cheers Sent from my iPhone using Tapatalk
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 Last edited by bugstrider; 04-11-2015 at 08:00 AM.. |
Fitted a water pump and thermostat to the C4S. Also rebuilt the SAI pump and put new bearings in it. Then found the blower motor was making a clicking noise as if something was hitting the fan blades. Pulled it out, tested, no noise. Reinstalled, still no noise....
Adjusted the cabriolet roof which was loose, then fitted a new mounting bracket for the front Litronic sensor. Next job, either IMS bearing upgrade or finding and re-installing a Becker CDR23 to get rid of the CAN bus faults that appear in Durametric scans. Gradually clearing all those OBD fault codes :-)
911 SC 1980
Not today but this week: Wiechers Sport roll bar.
911 SC 1980 Regularity Rally Car 996 C2 2000 Daily Driver Cayenne 3,6 2011 for wife and lab 924 Targa 1982 Sold! |
Certified User
Installed replacement oil cooler today and fixed rocker cover leak as well.
Yes, air filter housings too, but I have since swapped them out for something simpler. ![]()
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
This is truly the thing dreams are made of.......... Nice work. Sent from my iPhone using Tapatalk
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 |
Eva
uncovered, rolled out of garage, organizing garage
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Finished up my TTG lights install
Bob |
Drove the crap out if it today. I even let another Pelican take a turn at the wheel.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Brew Master
New Cap, rotor and plug wires installed then drove it.
Pulled her out of winter hibernation and took her out for the first drive of the year. Great to be back behind the wheel !
Doug '81 SC Coupe |
Tags |
fuchs are ugly , stock sucks |
