Un Canadien Errant
Installing a voltmeter, and a question
I've just completed installing a voltmeter into the dash of my beloved Brian. I was prompted to do this after a dead alternator left me stranded awhile back.
The install wasn't 'hard', and was cheap ($20 VDO voltmeter on ebay plus some wire) but took quite a lot of time from start to finish. I'd give the final result an 8 out of 10, mostly because of the hazard switch issue that I experienced... I'm very pleased with how the voltmeter turned out (got the idea from someone else's photo here) but the hazards were a bit disappointing. Because of the length of the hazard switch, when I inserted it into the new hole I'd made on the right of the steering column, it hit the heater cables behind the dash, which means the switch doesn't sit flush with the dash. It's hard to see and I don't think anyone but me will notice it, but it's a shame nonetheless. I may look at finding a collar or something to make it look more 'finished' - the challenge is that there's a pre existing hole that I used, so it kind of has to go in this location - moving it an inch lower would have looked strange. Anyway, my question - when I hooked up the voltmeter, I used one of the connections in the hazard switch itself for the power. (I made a short 'wiring harness' to extend the wiring from the existing location to the new one, and just split one of the connections). The connection I chose is always 'on', which means the voltmeter is too. Do you think this will draw a significant amount of power? Would I be better off finding a connection that is only live when the key's turned? Cheers Al
Alan ---- 1980 911SC - 'Brian' |
Senior Advisor
your good, any 12v source will work
08 Cayenne Turbo |
ROW '78 911 Targa
If it were me, I'd connect to a switched hot for the meter (ignition switch is right there) and figure out some sort of bezel extender ring for the hazard switch. Make sure nothing is touching the heater control cables back there. I had an A/C control switch there installed by the PO, I removed it when I saw sparks dropping at my feet! There is a nice small rocker switch there now for a blower fan.
As for the protruding switch, a simple bezel extender could be some stacked washers/spacers or equivalent. Sherwood |
non-whiner
You will be surprised how much current it will draw. It needs to be on switched power. Use the gauge power wire from one of the other gauges. That way it's also fused as intended.
Undocumented User
I was wondering why the picture shows 12 volts on the gauge and your comment about it being wired to a constant explains it.
I would just create a "bezel" of sorts to go around the new hazard switch. Some kind of black ABS plastic pipe in the correct diameter cut to a width of what looks to be about 6mm. Or as another op suggested, try to relocate that switch and put another "shorter" one in its place.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
One of these always comes in handy;
this model allows you to swivel the head so its easier to view.
RETIRED
Switched power is best. You WILL get a bit of a drop, check the differential with a meter to the battery and the posts on the alternator.
I hooked mine up originally straight to the battery, there was enough of a draw to kill it after a week. Airplanes turn the gauge power off due to extended down time.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Un Canadien Errant
The plastic pipe idea is excellent - I'll have a look in the hardware store. I'll find a nearby source of switched power and swap it over - thanks all.
As close as you can get to the battery (switched) is best..I wouldn't "share" any circuits if possible.
Best! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
+1 kuehl cheap and easy installation. Also, who use the lighter outlet anymore?
More bucks however, you can have your oil level gauge switched out to a volt meter. North Hollywood Speedometer and Clock Company. Serving your gauge needs since 1955. VDO, Porsche, Mercedes, BMW, Volkswagen, Veigel, Veglia |
