-   -   Another ST-build - this time from Denmark (http://forums.pelicanparts.com/porsche-911-technical-forum/733424-another-st-build-time-denmark.html)
Flojo 02-08-2014 06:02 AM
cool project!
Danish Dynamite 02-08-2014 08:29 AM
Time to get the 930 floating brake discs assembled!
The brakes looked like this when I bought them:
http://forums.pelicanparts.com/uploa...1391876319.jpg
http://forums.pelicanparts.com/uploa...1391876514.jpg
I disassembled them and had them straightend up:
http://forums.pelicanparts.com/uploa...1391876551.jpg
http://forums.pelicanparts.com/uploa...1391876562.jpg
The hats and rings were cleaned up, wire brushed and send to get black-chromed.
Hats freshly pushed into the discs and all new assembly gear:
http://forums.pelicanparts.com/uploa...1391876666.jpg
http://forums.pelicanparts.com/uploa...1391876727.jpg
Now to the wonderful job of getting the parts together:
http://forums.pelicanparts.com/uploa...1391876822.jpg
http://forums.pelicanparts.com/uploa...1391876831.jpg
All done:
http://forums.pelicanparts.com/uploa...1391876929.jpg
http://forums.pelicanparts.com/uploa...1391876934.jpg
jsveb 02-08-2014 09:41 AM
That looks really nice!
Who fixed the rotors for you?
Danish Dynamite 02-08-2014 09:44 AM
Thanks!
A guy at Au2parts in Ringsted
jsveb 02-08-2014 10:08 AM
Thank you. I'll remember that.
LukeyP 02-11-2014 02:15 PM
Great work... Body looks beautiful!
Danish Dynamite 02-20-2014 11:15 AM
My car is now at "Porsche Centrum Køge" - a well known Porsche shop in Denmark. They installed the headliner and the windows and while doing other work on the car, they let me work on the car while in the shop:
http://forums.pelicanparts.com/uploa...1392923198.jpg
http://forums.pelicanparts.com/uploa...1392923212.jpg
http://forums.pelicanparts.com/uploa...1392923253.jpg
The great guys there had a laugh when I was laying flat inside the car installing the pedal box and took a picture:
http://forums.pelicanparts.com/uploa...1392923389.jpg
Powder coated roll cage installed:
http://forums.pelicanparts.com/uploa...1392923498.jpg
http://forums.pelicanparts.com/uploa...1392923506.jpg
The owner, Kim, talked me into installing a new sound deafning in the eninge compartment. That was a "wonderful" job, and I had to take of the air cleaners, but the final result was nice...
http://forums.pelicanparts.com/uploa...1392923636.jpg
http://forums.pelicanparts.com/uploa...1392923644.jpg
The part I took out was from 1972 and increadably heayy! The new part weighs nothing...
Danish Dynamite 02-20-2014 11:22 AM
I also restored my one year special oil tank. That took a lot of hard work!
Old and dirty:
http://forums.pelicanparts.com/uploa...1392923875.jpg
http://forums.pelicanparts.com/uploa...1392923881.jpg
http://forums.pelicanparts.com/uploa...1392923889.jpg
Grinding:
http://forums.pelicanparts.com/uploa...1392923896.jpg
http://forums.pelicanparts.com/uploa...1392923902.jpg
Zink coated:
http://forums.pelicanparts.com/uploa...1392923941.jpg
http://forums.pelicanparts.com/uploa...1392923948.jpg
Painted with a "Hammerite" kind of paint:
http://forums.pelicanparts.com/uploa...1392923909.jpg
http://forums.pelicanparts.com/uploa...1392923917.jpg
http://forums.pelicanparts.com/uploa...1392923925.jpg
will hung 02-20-2014 11:46 AM
Very cool. I installed my pedal box the same way. Removed the steering wheel and driver's seat. Made the entire process way easier.
Flojo 02-20-2014 11:58 AM
nice brakes.
one good trip through the hills and its all spoiled ;-)
Danish Dynamite 03-30-2014 11:32 AM
Lots of updates coming up. Lots of work done. Just haven't had the time to post...
But here is a video of the first start of the engine in 2½ years :D
The new exhaust might be too loud, but I have a plan for that...
https://www.youtube.com/watch?v=50vJHiDLi8M&feature=youtu.be
/Christian
quozl 03-30-2014 11:45 AM
Nice work!!
It must be an amazing feeling after two years and all the hard work you have put in.
Not too loud at all, love the note, keep it as it is.
Cheers Al
Flieger 03-30-2014 12:19 PM
Sounds great!
Danish Dynamite 03-30-2014 12:20 PM
Thanks, guys!
It might be hard to hear on the video, but it is REALLY loud...
Danish Dynamite 03-30-2014 01:15 PM
A little more from today. I had to block off the chocker for the MFI as I am running headers... Fun work.
Before:
http://forums.pelicanparts.com/uploa...1396210423.jpg
After:
http://forums.pelicanparts.com/uploa...1396210483.jpg
http://forums.pelicanparts.com/uploa...1396210490.jpg
Flieger 03-30-2014 03:38 PM
Make sure that screw is not too tight. The thermostat rod on mine ended up breaking and necessitating a total rebuild of the pump when the rod got into the cam and lifter area and seized up #3 and #6.
Danish Dynamite 03-30-2014 08:43 PM
Thanks, for the advise! I will back it off a bit :)
Flieger 03-30-2014 09:09 PM
Well, there is a correct length for the warmed-up position. You just don't want to go past that. I am not sure what the tolerance is.
jm993rs 03-31-2014 02:28 PM
Please sr Danish !! Any pic of the oiltank connections and mounted ??
I love tjis oiltank and I Would mount this !!
Thank you
Danish Dynamite 04-05-2014 01:35 AM
Hey Max. Thanks again for the advise. It actually showed out, that I had not tighten it enough! I took of the side cover to see what was happening - and manually tested the play with a thin allen wrench. Here are some "open heart" pictures to show the open (chocker) position and the closed (non-chocker position)
Open:
http://forums.pelicanparts.com/uploa...1396686845.jpg
Closed - the rod easy pressed in by hand with the allen wrench
http://forums.pelicanparts.com/uploa...1396686083.jpg
I then put in a longer allen screw and carefully measured and observed when it reached the closed position.
Before tightning:
http://forums.pelicanparts.com/uploa...1396686680.jpg
Tightent to the closed position:
http://forums.pelicanparts.com/uploa...1396686685.jpg
