probs w/964s?
so now we're looking at 964's
in our price range they typically have plus 100k miles on 'em
what major work should i anticipate if the engine hasn't been rebuilt.
thanks. Again.
ed
ed's flyfishing outfit
bozeman, mt
'92 964 C4
chevy p/u
Old 02-22-2013, 07:53 AM
vtdriver's Avatar
Oil leaks. Pre '91 engines were gasketless and very leaky. Re-seals are expensive.
HVAC Fans and servos are expensive and hard to trouble shoot.
-Tim
91 964 GPW/Cobalt with RSA seats etc.
Previous:
81 SC sold to Zach!,75 Euro Spec,68 S Spec
Old 02-22-2013, 08:13 AM
servos are not available new or rebuilt either. That is what was the tipping point and the sale of my 964.
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 02-22-2013, 09:08 AM
Apart from compression and leakdown numbers, you also want to look at the dual plug distributor. If it has never been replaced, you will need to do that. The rubber belt drive deteriorates from ozone created by sparking. Porsche came out with a 'fix' and that was to plumb in some fresh air from the cooling fan to blow air into the distributor to dilute the ozone. Even with that fix in place, the belts last about 15 yrs MAX...we are now in year 20 + depending on which MY you choose.
Tony G
2000 Boxster S
Old 02-22-2013, 09:24 AM
mrehrer's Avatar
Is there a drop in replacement for the siamese twin plug distributor?
Old 02-22-2013, 09:35 AM
GaryR's Avatar
Send a message via ICQ to GaryR
The distributor does NOT have to be replaced, the belt replacement is all it needs and it isn't all that expensive to have replaced. The pre-92's had no head gasket. MANY have been re-machined to take the gasket, and even if they didn't it doesn't mean there is an issue. Get a PPI and have it checked out, go from there.
Gary R.
Old 02-22-2013, 09:39 AM
The belt is not that easy to replace and a remanufactured distributor is about 200 bucks (core exchange) and not dificult to replace. Either way, the belt is the weak link there.
Tony G
2000 Boxster S
Old 02-22-2013, 09:43 AM
thanks. Again.
Look at the 92 C2 and up model year. Do a PPI.
Major work at 100k miles on these C2 model years if they have never been done.
1. Clutch, PP, fork upgrade and new DMF flywheel
2. Distributor belt
3. Alternator VR, belts and bearings
4. Torn CV boots maybe
5. Rear wheel bearings
6. If it smokes on decel, valve guides
7. Power steering drive seals
8. Oil leak at breather, oil pressure sensor
9. Oil tank hoses
10. Spark plug wires and coils
If you don't diy, will cost a lot of money.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
some are pretty dry and some leak starting at the front oil cooler, steering rack and hoses, rocker oil lines, oil tank and hoses, steering pump seal and every joint on the engine. find a dry one.
206 637 4071
Old 02-22-2013, 09:44 AM
GaryR's Avatar
Really? That's CHEAP for a rebuilt twin plug dizzy (if it's really rebuilt)!
Gary R.
Old 02-22-2013, 09:48 AM
hmmmm...
looks like i'll have to expand my thinkin$.
thanx, gents.
ed
bozeman, mt
'92 964 C4
chevy p/u
Old 02-22-2013, 10:02 AM
sent you a PM
Tony G
2000 Boxster S
Old 02-22-2013, 10:11 AM
hmmmm...
thanx, gents.
Ask the same question in the 964 forums before you decide.
'90C4
Old 02-22-2013, 01:42 PM
Senior Advisor
James Brown's Avatar
i don't think there any different than SC, Carrera cars, just normal upkeep and routine maintenance, find a good one. there is a good dissy belt discussion going on now in the forum, belts bushings and bearings every 50k miles will make it happy. Accessories on later cars will add to cost overall but almost all the mods you would want to do to early cars are factory done (big breaks, coil overs, better transmission, higher horsepower, better air-condition, safer) so, it's a trade off.
08 Cayenne Turbo
Old 02-22-2013, 03:10 PM
f3nr15's Avatar
New servos are available but are expensive.
They come up cheap on eBay from time to time if you're diligent - I've snagged 4 new servos for cheap that way.
Finally, a German Rennlister rebuilds them. Better than new, with better components than the factory. Not cheap, but it's a 20 year old Porsche, and the best of the air-cooled.
The rest of the naysaying in this thread is "worst case scenario" stuff. Do your homework and get a proper PPI, and you won't look back. A well maintained 964 is the BEST buy in the Porsche world right now. Bar none. Check out Rennlist's 964 forum and ask the folk who live with them everyday, rather than relying on other folks' second hand opinions.
Regards,
Peter
1992 928 GTS
1993 964 Carrera 2 Coupé
Old 02-22-2013, 03:47 PM
Senior Advisor
what servos?
08 Cayenne Turbo
Old 02-22-2013, 04:10 PM
f3nr15's Avatar
Five HVAC servos - in a suitcase in the frunk ;-)
Regards,
Peter
1992 928 GTS
Old 02-22-2013, 04:17 PM
Senior Advisor
oh, servos? we don't need no stinking servos!!
08 Cayenne Turbo
Old 02-22-2013, 04:20 PM
RETIRED
Joe Bob's Avatar
Good donor cars for SCs and 914s.....
2012 ML350 3.0 Turbo Diesel
Old 02-22-2013, 04:22 PM
Like.
'90C4
Old 02-23-2013, 07:48 AM
