Steering is assembled...
K-Jetronic student
Old 07-15-2013, 01:27 AM
Front and rear brakes (not finished)...
K-Jetronic student
Old 07-15-2013, 01:29 AM
andy_uranium's Avatar
Looks amazing! Subbed for future progress, keep it coming.
DD - 2011 VW MK6 GTI - Candy White
Currently seeking a 911 Carrera or SC
Old 07-15-2013, 03:50 AM
A few more developments on this project.
An issue with the brake upgrade that was supposed to be a bolt in solution, needed up being a time waster while other things could have been assembled...
Never mind...
Basically some more interior had been assembled.
Working with the fiberglass panel for the dash top, was a terrible experience. At the end we manage to find a way to attach it
K-Jetronic student
Old 12-16-2013, 12:01 PM
The hole fire extinguisher system is finished (not yet when the photos were taken).
Also the braKe lines are all installed, as well as the hydraulic hand brake.
K-Jetronic student
Old 12-16-2013, 12:08 PM
Still a long way to go...
K-Jetronic student
Old 12-16-2013, 12:11 PM
Working with fiberglass was not a pleasant experience... But for the first time, the final result was not so bad...
K-Jetronic student
Old 01-05-2014, 03:00 AM
Doors are almost done...
Door top trim had to be modified because of the roll-cage.
K-Jetronic student
Old 01-05-2014, 03:02 AM
Wow that is looking really impressive Alex!
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 01-05-2014, 08:04 AM
Wer bremst verliert
JohnJL's Avatar
very nice, keep posting progress!
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 01-05-2014, 03:10 PM
Banned
I'm curious about your painting on the bottom.
Since it will be hit by lots of rocks did you use an epoxy paint?
Or powder coating? I've heard that powder coating is hard but chips and is then difficult to repair.
What went into your thinking on the paint or treatment for the bottom of the car?
Old 01-05-2014, 03:38 PM
Thank you all for your comments.
Gearya, this is a car to be used in tarmac. In tarmac rallys there is not so much agression from rocks or dust.
The bottom was painted with a black chassis paint for extra protection, over epoxy paint. All the rest was painted with normal paint including the wheel arches where I like to show all the reinforcements done.
K-Jetronic student
Old 01-07-2014, 12:43 AM
Doors ready. Very pleased with the result
K-Jetronic student
Old 01-13-2014, 03:28 AM
paul284pt's Avatar
This is really impressive
Geat work Alex, keep the posts coming.
Good luck,
Paul
Old 01-13-2014, 04:51 AM
Thanks Paul!
K-Jetronic student
Old 01-13-2014, 11:33 AM
New Mocal oil cooler already in place:
K-Jetronic student
Old 01-17-2014, 02:38 AM
I had to build new supports and brackets for the new cooler.
All built in aluminum and protected with powder coat.
K-Jetronic student
Old 01-17-2014, 02:40 AM
On this group of parts, also the coil bracket to install it on engine compartement:
K-Jetronic student
Old 01-17-2014, 02:42 AM
Inspiring work Alex!
Is that a Ford EDIS coilpack? Also, are you going with the D-Zug / Kosmal EFI ITB setup?
Thanks for sharing!!!
Old 01-19-2014, 11:06 PM
Hi flat6heaven,
Yes, Dzug/Kosmal set up. Ford coil.
K-Jetronic student
Old 01-19-2014, 11:51 PM
