BoxsterGT's Avatar
Porsche Crest Help needed to get front lid open on early 911
I am unable to open the front trunk on my 69 911.
Never, ever had this problem before. The release handle will not budge.
Unfortunately, its been out in the weather for a few years, and the cable or latch may have frozen or rusted in place.
Thinking of a slide hammer to pull on the release handle, but don't want to break it.
Any suggestions from the experts here on Pelican?
Thanks in advance.
Len
Old 03-01-2013, 06:59 AM
suggestion
I had to replace my latches on the front and rear hood. Haven't been able to get the front hood latch lined up so everytime I shut it there is only one way for one person to open the hood. The dash cable pull will disengage the safety so that the hoods pops open but I can't get the latch to unlatch. My solution is I pull out the cable as far as possible and put a clamp on the wire to keep the wire extended full. Then, I can go to the front and get the latch open. I use a clamp from a battery charger to hold the cable as it seems to be just the right size. Don't know if that'll help but it works for me.
I remember that there are several threads here that I referenced to end up with my fix. Some threads suggested drilling and cutting and drastic crap like that. Try some other solutions from other threads before surgery.
Old 03-01-2013, 07:35 PM
Try with two persons, one to pull the release cable and one tries to open the trunk
I have seen a diagram that explains where to drill some holes to open the trunk if the release wire breaks, but do not remember where.
Old 03-01-2013, 07:42 PM
ROW '78 911 Targa
timmy2's Avatar
You didn't happen to lock the handle before parking it did you?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-01-2013, 09:21 PM
BoxsterGT's Avatar
Porsche Crest
Its a Targa with a lockable handle, but it is not locked and I opened it last summer and it was OK. If I break the handle/cable it should release on its own, but... should is the key word here.
Hate to cut into a good long-hood, but what other way is there. Perhaps drop the bumper and cut thru the front valence? Can I get the front bumper off from below?
Len
Old 03-02-2013, 05:48 AM
esses62's Avatar
should be a access hole behind front bumper to manually release latch
Scott
88 911 G50 3.2 Targa Signal Red DP935 NA
95 993 C2 Coupe Black/Black
99 996 C2 Silver/Blue
77 911S GP White/Cork
Old 03-02-2013, 05:57 AM
AutoBahned
RWebb's Avatar
I. Emergency Tricks for 911
A. Fuel Filler Lid Release
Get a flat cotton cloth shoestring. Slip it under the rear of the fuel door, hold both ends of the shoestring and pull it gently toward the front of the car. The fuel door will spring open.
You can practice this parlor trick anytime. I've opened mine with the bottom of my T-shirt as another emergency measure.
Carry a spare shoestring in your emergency bag.
B. Rear Deck Lid
C. Front Trunk Lid
Get a helper and while they pull on the release, yank up swiftly on the hood. It should let go after a few tugs. Then you can readjust the cable at the release mechanism to accommodate the additional friction from the new hinge placement.
Old 03-02-2013, 12:23 PM
My front trunk lid was stuck, and I tried using a cheap air bladder, like the kind used to separate a window to get into a car easily, and it popped open. It was easy and nondestructive. I doubt it will help all problems, and don't keep the bladder in the trunk...lol.
Old 06-11-2018, 01:20 PM
Been here a while
2 people. Have one push down on the hood while the other pulls the release......then....push the hood towards the passenger fender....down and left.......
looking for 1972 911t motor XR584, S/N 6121622
Old 06-11-2018, 03:25 PM
l_turn9's Avatar
Found the sketch below in the WorkShop Manual. It tells how to open the trunk if the release cable breaks,
Larry
Youroil.net
Weber & PMO
Old 08-13-2021, 12:57 PM
BoxsterGT's Avatar
Porsche Crest
Hey Larry, where is the sketch you were going to post?
Len
Old 08-27-2021, 08:33 PM
Len,
Once, on my ‘68, a Lug wrench found it’s way into the slot for the front latch preventing me from opening the hood. I parked the car on a steep incline, nose facing up and bounced on the front bumper until the lug wrench slid out of the hole. Hope that’s your problem
Tony
1973 914 2.2 FAT Black
1974 911 Targa Lime Green
2018 Macan GTS White
2019 Targa GTS Agate Grey
Old 08-28-2021, 08:27 AM
