kinein's Avatar
Send a message via Yahoo to kinein
spun out on freeway goin about 70 mph
So a few weeks ago i had a blow out on driverside tire, which caused me to spin on the freeway, at times even goin backwards while foot was on the gas. It happen so quickly, now it wont go into 5th .
I only drove it home afterwards. I was 100 miles from home. Now what type of damage do you think couldve occured during this incident? (excuse the typing i am doin this while working with patience looking at me) do you think there can be possible tranny issues? and suspension? i run 335 30 18 tires in the rear, and the force just pulled it right off. soon to post pics on the damage to the car.
1966 912 with 2.2 911 motor
1986 wide body 911
1995 993 Polar Silver
Old 03-13-2013, 03:17 PM
Hell Belcho
Nostril Cheese's Avatar
yeah, it's possible you screwed up the shift linkage. Having ultra low profile tires probably didnt help either.
Old 03-13-2013, 03:41 PM
kinein's Avatar
what about 5th gear itself? would you think there can be any issues there?
1986 wide body 911
Old 03-13-2013, 03:42 PM
Member 911 Anonymous
DRACO A5OG's Avatar
yes, if linkage got damaged, it may be out of alignment
'85 Carrera Targa
PCA/POC
Old 03-13-2013, 03:45 PM
LJ851's Avatar
What does not going into 5th feel like? Does it go into reverse fine?
It's possible the vacuum created by your sphincter when the tire blew disturbed an adjustment.
Old 03-13-2013, 03:47 PM
Checked out
McLovin's Avatar
other than the sphinter theory, I can't see how the shift linkage could have been affected.
Old 03-13-2013, 03:50 PM
kinein's Avatar
it just wont go into 5th.
as far as the sphincter it couldve disturbed alot of the adjustment.
1986 wide body 911
Old 03-13-2013, 03:53 PM
kinein's Avatar
Wheni get home I am goin to post some pictures. I just wondering what I need to have looked at. Suspension? Transmission? etc....
1986 wide body 911
Old 03-13-2013, 03:57 PM
Senior Advisor
James Brown's Avatar
things shift when sideways at speed, just a little misalignment can cause that, check the trans and engine mounts, if there still there, go with a coupler realignment doubt you broke anything.
08 Cayenne Turbo
Undocumented User
McLaren-TAG's Avatar
Out of curiosity where did the blow out come from? You think you maybe have overlooked some damage to the tire that just got worse? Rubbing? Old rubber? Neglect?
I've never experienced a blow out, and hope I never do.
Old 03-13-2013, 04:03 PM
Been there and unfortunately have done that. At speed and accelerating on a slight curve to an on ramp to the interstate. Right rear tire lost the bead seal. Probably low pressure. 90º left followed by 180º right - then straightened it out just in time for the dirt shoulder. Blew out 3 tires, took out the spoiler which took out the front bumper.
I was lucky - no suspension or mechanical damage.
You were VERY lucky that no cars were too close to you - it could have been alot worse!
08 Aston Martin Vantage V-8 (6 spd manual) (DD)
20 Cayenne white-black/red (hers)
78 930 (heavily modified)
08 GT3 RS (white/black) (modified of course)
67 911S outlaw (sold)
Old 03-13-2013, 04:20 PM
kinein's Avatar
Something cracked my wheel. which cause the tire to deflate which cause the car losing control. the tires were brand new.
1986 wide body 911
Old 03-13-2013, 05:38 PM
Project Addicted
The engine and trans are rubber mounted so a wicked slide may ba able to throw something out of alignment. If there was also in ampact from the side, that could be a factor too. Which could cause the shift linkage to be out of whack. That is an easy and cheap p,ace to start looking.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 03-13-2013, 05:48 PM
Capitalist and Patriot
911Freak's Avatar
Any chance the tire installation damaged your wheel and it became a ticking time bomb? Seems like more then just a coincidence you had new tires put on then a wheel just happen to crack and you flat spin at speed! Have you inspected all the other wheels carefully?
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 03-13-2013, 06:02 PM
kinein's Avatar
well the wheels are done i cannot get another set of kineisis. i am about to post the pics of the rim
1986 wide body 911
Old 03-13-2013, 06:04 PM
kinein's Avatar
1986 wide body 911
Old 03-13-2013, 06:20 PM
tire shop issue? those machines can do some damage if the operator is not careful.
206 637 4071
Old 03-13-2013, 06:56 PM
LJ851's Avatar
In the second pic you can see localized damage to the tire at the same point as the rim is damaged, looks to me like something got run over and caused the damage.
Old 03-13-2013, 07:00 PM
Hell Belcho
Low profile tires + big wheels + old car. You hit a rock and bang.
The sideways force that cause the tire to do that will also have shifted the axles, trailing arms, etc..
Were you IN fifth gear when this happened?
Old 03-13-2013, 07:08 PM
kinein's Avatar
yes i was in 5th gear, i am concerned about the tranny
1986 wide body 911
Old 03-13-2013, 07:55 PM
