Local Mad Scientist
Andy911sc's Avatar
Breaking into the Differential to find the Magnets
Tonight I will be starting on project titled "Operation: Rescue Magnets." I will be draining the tranny, removing half shafts and cracking open the differential. Repair and back together.
Some while I am in there work:
Rebuild CV Joints
Inspect rear hubs (see if bearings need replaced)
Repair the mag ring so my speedometer read the correct speed.
Hopefully be done in 3 weeks for the Hershey Swap Meet.
And as always, pictures to follow the progress.
1982 Porsche 911sc
2009 Jeep Grand Cherokee Laredo X
CPA-PCA Member Since 2012
Old 03-18-2013, 09:12 AM
Local Mad Scientist
Andy911sc's Avatar
Question: Should I get all new allen bolts for the CV joints or reuse what I take out if they are in good shape?
1982 Porsche 911sc
Old 03-18-2013, 12:11 PM
Senior Advisor
James Brown's Avatar
up to you, there just bolts, how many you mangle is up to you! get new lock washers if you must but there made for reuse. You sure the magnet ring is the problem?
08 Cayenne Turbo
Old 03-18-2013, 12:14 PM
Local Mad Scientist
Andy911sc's Avatar
Yeah, when I had the multimeter set up for continuity beeps, it only made 4 instead of the 8. I had the speed sending unit disconnected and straight to the multimeter, so no interference from anything else. I would like to think it's something else, but when you only get 4 and everyone says 8, it kind of narrows things down. I was informed that I could have some corroded or gummed up magnets hindering the signal. My P-mechanic did tell me that he has seen this happen before. Either way, It isn't worth playing a guessing game about with the risk of a loose magnet getting caught in my differential gears.
1982 Porsche 911sc
Old 03-18-2013, 12:43 PM
Senior Advisor
yep, ok it is a PITA just to change that, just making sure. so WYIT, put in a posi unit!!
08 Cayenne Turbo
Old 03-18-2013, 12:51 PM
Local Mad Scientist
Andy911sc's Avatar
If I had the funding for a LSD, I would. Still recovering from last years medical bills. Right now, I am trying to keep it cheap with cv joint rebuild kits and possibility of new rear hub bearings (depending condition).
1982 Porsche 911sc
Old 03-18-2013, 12:57 PM
KTL KTL is offline
Schleprock
KTL's Avatar
A box of 25 M8 x 50 socket head screws from McMaster Carr is like $8. Cheap insurance against stripping out a bolt head and having to fiddle with a pair of vise-grips to get it out.
For my racecar I chose to get 55mm screws, use the serrated lock washers (also get at McMaster) and also some moon plates from a VW performance shop. Had to get the plates from a VW shop because it appears the Porsche 901.332.191.00 plate (this is the part number that superseded 113.501.329) is no longer available
Vintage VW Parts | New last 6 months | torque spacer cv bolt to joint | 113501329
The plates are a bit of overkill but they do help spread the load of the bolt and give the serrated lock washer something hard to bite into. This bite is especially important when you consider some CV joint boot flanges are soft stamped metal.
Kevin L
'86 Carrera "Larry"
Old 03-18-2013, 12:58 PM
Local Mad Scientist
Andy911sc's Avatar
I was considering moon plates. I thought our host had them. Also the washer, is that the schnorr washer? Highly considering new bolts anyway that weren't preloaded yet with the stress from the cv joints.
1982 Porsche 911sc
Old 03-18-2013, 01:05 PM
schumicat's Avatar
I would replace any allen bolts which show any damage from removal. peps boys has the correct bolts in stock (at least the one by me did) if you just need 1-2. it is really easy to get the diff out and back in. use a new o ring for the diff cover.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-18-2013, 01:08 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Yep that Schnorr type is a belleville spring-type that is serrated on both sides so it bites good.
The only moon plates Pelican has are the M10 size that I can find.
Kevin L
'86 Carrera "Larry"
Old 03-18-2013, 01:09 PM
Local Mad Scientist
Andy911sc's Avatar
Yeah I just looked and saw that. SC's are the M8 then. Thanks for the link for the VW source. I will have to definitely pick them up.
I was looking for an o-ring for the cover but didn't have any luck. Would you know where I can source one?
1982 Porsche 911sc
Old 03-18-2013, 01:15 PM
Local Mad Scientist
Andy911sc's Avatar
I thought I remember seeing guys that used safety wire and wired two heads together along with moon plates and schnorr washers. Is there a kit for that, or did they just drill a small hole through the heads for the wire diameter?
1982 Porsche 911sc
Old 03-18-2013, 01:17 PM
Air Cooled
Craig_D's Avatar
I was considering doing this to mine. What you'd do is drill two holes on opposing sides of the allen bolt, then run safety wire through the hole, and rap it around the torquing side of the bolt (to the clockwise direction), then run the loop to the left side neighboring allen bolt.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 03-18-2013, 01:25 PM
cashman's Avatar
You may only get 4 hits. Check out my posts here starting on post#13. Speedometer has been working ever since. I am convinced I only ever received 4 hits per rotation.
Speedometer, CASIS, Cruise Problem
FWIW I also posted a picture of the sending unit here on post #37
G50 Speedometer Sensor Problem
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 03-18-2013, 01:30 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The safety wire routine is nice if you can find the bolts pre-drilled. To drill your own you need to jig them in a holder to help you drill straight.
There's a picture in this thread that shows how they're typically done
CV Torx Bolt sources?
The o-ring is not listed in Pelican's catalog. But any time you want, you can enter the Porsche part number and Pelican can get it for you. The diff cover o-ring is 999-701-392-40
Kevin L
'86 Carrera "Larry"
Old 03-18-2013, 01:37 PM
Fleabit peanut monkey
Bob Kontak's Avatar
+1 I have looked, can't find them.
Pretty sure the direction you are giving is the best route to go re: moon plates/schnoor.
1981 911SC Targa
Old 03-18-2013, 01:45 PM
Daugaard's Avatar
Hi.
Diff cover O-ring is 3,5 x 202 mm
I think you can find it in a shop near you or on internet.
Daugaard
Daugaard
Old 03-18-2013, 02:17 PM
Local Mad Scientist
Andy911sc's Avatar
Cashman, I have an 82sc so my speed sending unit is different from your. I have the 915 transmission. I am not sure if I have an after market LSD installed. I noticed someone asked in your thread if an LSD would mean that the plate would only half rotate with a full revolution of one wheel. I am curious though, because my last speed sending unit read the same place this one is. I have just replaced with a new one.
Here is the picture from my test:
1982 Porsche 911sc
Old 03-18-2013, 04:19 PM
cashman's Avatar
That's pretty much the same pattern I have. I'm not a statistician but I found it very inconceivable that every other magnet happened to fall out. What are the odds of that?
Once I got the OEM replacement cable I have had no problems. 5000 miles and 6 DE'S Later.
I believe the test to check for LSD is to jack the rear, go in neutral, rotate one tire, observe the other tire, if it rotates the same direction you have LSD. Opposite direction you do not. I do not on mine. Do a search and double check me on that.
Old 03-18-2013, 05:03 PM
Local Mad Scientist
Andy911sc's Avatar
Being a chemist and knowing statistics the chances that I have every other missing, I would have better luck winning the lottery. I am reading slow on my speedometer though. Example (my gps which is very accurate would read 45mph and my speedo would only read 35 mph.) I just had my speedo out for repairs, but it was acting exactly like this before repairs (repairs where for the odometer gear). So, I replaced the speed sending unit and same result. My P-mechanic is leaning towards gumbed up or missing magnets. This all started after I tried to use my cruise control. He feels that it is unrelated and just coincidence. He told me that if I cancel out the cruise via switch then symptoms should go away and they haven't.
1982 Porsche 911sc
Old 03-18-2013, 05:12 PM
