Running CIS on 80-83 3.0L w/o using brain/o2
Hi, Can any one give me info on running a 3.0 L without the brain/ oxigen sensor set up. What would be required to run this way and would it work properly. I am looking at installing a 3.0 L in my 77S and one mechanic said you could install it without the brain/02 setup or even use the complete CIS setup off my 77S on the 3.0 L. Any thoughts on this, Thanks
Old 07-11-2002, 09:15 PM
I don't know about NY but here in CA it wouldn't smog.
Joe
Old 07-11-2002, 11:32 PM
Talonz82's Avatar
Hello, you can eliminate some of the circuits but not all, the ECU controls the frequency valve and if it does not work, the car will run, but very poorly, I can send you a electrical diagrahm if you need one.
I have a 80 3.0, I set the mixture with the O2 disconnected and leave it disconnect for overall driveability
Peter
Old 07-12-2002, 03:37 AM
Sean Hamilton's Avatar
Thumbs up GMR911
email fellow member "Hladun".
you'll find him in member search under - H - page 5.
He's done some good tech articles on CIS mods.
Cheers, Sean.
94 911 Carrera 2 993 Cab
http://www.pelicanparts.com/gallery/Sean_Hamilton
Old 07-12-2002, 09:53 AM
