Local Mad Scientist
Breaking into the Differential to find the Magnets
Tonight I will be starting on project titled "Operation: Rescue Magnets." I will be draining the tranny, removing half shafts and cracking open the differential. Repair and back together.
Some while I am in there work: Rebuild CV Joints Inspect rear hubs (see if bearings need replaced) Repair the mag ring so my speedometer read the correct speed. Hopefully be done in 3 weeks for the Hershey Swap Meet. And as always, pictures to follow the progress.
1982 Porsche 911sc 2009 Jeep Grand Cherokee Laredo X CPA-PCA Member Since 2012 |
Local Mad Scientist
Question: Should I get all new allen bolts for the CV joints or reuse what I take out if they are in good shape?
Senior Advisor
up to you, there just bolts, how many you mangle is up to you! get new lock washers if you must but there made for reuse. You sure the magnet ring is the problem?
08 Cayenne Turbo |
Local Mad Scientist
Yeah, when I had the multimeter set up for continuity beeps, it only made 4 instead of the 8. I had the speed sending unit disconnected and straight to the multimeter, so no interference from anything else. I would like to think it's something else, but when you only get 4 and everyone says 8, it kind of narrows things down. I was informed that I could have some corroded or gummed up magnets hindering the signal. My P-mechanic did tell me that he has seen this happen before. Either way, It isn't worth playing a guessing game about with the risk of a loose magnet getting caught in my differential gears.
Senior Advisor
yep, ok it is a PITA just to change that, just making sure. so WYIT, put in a posi unit!!
08 Cayenne Turbo |
Local Mad Scientist
If I had the funding for a LSD, I would. Still recovering from last years medical bills. Right now, I am trying to keep it cheap with cv joint rebuild kits and possibility of new rear hub bearings (depending condition).
Schleprock
A box of 25 M8 x 50 socket head screws from McMaster Carr is like $8. Cheap insurance against stripping out a bolt head and having to fiddle with a pair of vise-grips to get it out.
For my racecar I chose to get 55mm screws, use the serrated lock washers (also get at McMaster) and also some moon plates from a VW performance shop. Had to get the plates from a VW shop because it appears the Porsche 901.332.191.00 plate (this is the part number that superseded 113.501.329) is no longer available Vintage VW Parts | New last 6 months | torque spacer cv bolt to joint | 113501329 The plates are a bit of overkill but they do help spread the load of the bolt and give the serrated lock washer something hard to bite into. This bite is especially important when you consider some CV joint boot flanges are soft stamped metal.
Kevin L '86 Carrera "Larry" |
Local Mad Scientist
I was considering moon plates. I thought our host had them. Also the washer, is that the schnorr washer? Highly considering new bolts anyway that weren't preloaded yet with the stress from the cv joints.
I would replace any allen bolts which show any damage from removal. peps boys has the correct bolts in stock (at least the one by me did) if you just need 1-2. it is really easy to get the diff out and back in. use a new o ring for the diff cover.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Schleprock
Yep that Schnorr type is a belleville spring-type that is serrated on both sides so it bites good.
The only moon plates Pelican has are the M10 size that I can find.
Local Mad Scientist
I was looking for an o-ring for the cover but didn't have any luck. Would you know where I can source one?
Local Mad Scientist
I thought I remember seeing guys that used safety wire and wired two heads together along with moon plates and schnorr washers. Is there a kit for that, or did they just drill a small hole through the heads for the wire diameter?
Air Cooled
I was considering doing this to mine. What you'd do is drill two holes on opposing sides of the allen bolt, then run safety wire through the hole, and rap it around the torquing side of the bolt (to the clockwise direction), then run the loop to the left side neighboring allen bolt.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
Speedometer, CASIS, Cruise Problem FWIW I also posted a picture of the sending unit here on post #37 G50 Speedometer Sensor Problem
1989 911 Carrera Cab 25th Anniversary Edition Euro Pre-Muffler, SW Chip There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad" |
Schleprock
The safety wire routine is nice if you can find the bolts pre-drilled. To drill your own you need to jig them in a holder to help you drill straight.
There's a picture in this thread that shows how they're typically done CV Torx Bolt sources? The o-ring is not listed in Pelican's catalog. But any time you want, you can enter the Porsche part number and Pelican can get it for you. The diff cover o-ring is 999-701-392-40
Fleabit peanut monkey
Pretty sure the direction you are giving is the best route to go re: moon plates/schnoor.
1981 911SC Targa |
Hi.
Diff cover O-ring is 3,5 x 202 mm I think you can find it in a shop near you or on internet. Daugaard
Daugaard |
Local Mad Scientist
Here is the picture from my test:
That's pretty much the same pattern I have. I'm not a statistician but I found it very inconceivable that every other magnet happened to fall out. What are the odds of that?
Once I got the OEM replacement cable I have had no problems. 5000 miles and 6 DE'S Later. I believe the test to check for LSD is to jack the rear, go in neutral, rotate one tire, observe the other tire, if it rotates the same direction you have LSD. Opposite direction you do not. I do not on mine. Do a search and double check me on that.
Local Mad Scientist
