LinkBack | Thread Tools | Rate Thread |
Always Be Fixing Cars
Am I missing a relay/fuse ? 87 Carrera with empty socket in engine fuse block
Just wondering...
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
You are missing nothing. Used to set the idle. May have other uses. I don't believe the idle set procedure is in the Bentley manual but it is in the Haynes. What you see is normal.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
Irrationally exuberant
The relay for the missile launcher goes there. :-)
It's a test port. Running a jumper between 2 of the pins disables the idle correction so you can adjust the idle.
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
No, but you have a fuse that needs to get straightened out
88 Carrera - Venetian Blue 2002 Audi S4 Avant (KIA) |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Test connector.
Used to set the idle set screw on the throttle body.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
So put me on a highway
1985 911 Euro Cab. |
