One for A/C guru's...
While removing my UNGO box from my '78 SC, I noticed some wires in the trunk that led over to the driver's side wheel well. Looking in the wheel well, I found a 'nut' with wires attached coming from the trunk.
I looked around today after taking the wheel off so I could see better, and I found a hole in the dryer for the A/C that was covered with tape. The 'nut' has a stud coming off it and low and behold, that stud is the same thread as the hole in the dryer. ![]() As you can see, I've installed the 'nut' in the hole in the dryer. It was pretty obvious from the dirt on both the 'nut' and the tape over the hole in the dryer, that these have been apart for quite some time. My A/C blows cold air, but isn't used much here in SoCal. Will my putting the 'nut' back in the hole in the dryer affect the running of the A/C? Can you give me any reason(s) why it would have been left undone? Thanks for any help here. I just don't want to blow up my A/C system.
Scott '78 SC mit Sportomatic - Sold |
Been here a while
does the ac really blow cooler than outside/ambient air? I find this hard to believe......I am confident that's the low-pressure switch for the A/C system, so if the whole thing is removed, you'd lose all the refrigerant, meaning the a/c system won't blow cold air.
I can't imagine who would remove this, if someone diagnosed that the a/c wasn't turning on, and it was because of the low pressure switch, they'd have to evacuate the system in order to swap out the switch.....makes no sense to remove it and tape it up.
looking for 1972 911t motor XR584, S/N 6121622 |
If you look at this tech article: Pelican Technical Article: Air Conditioning Compressor Upgrade
You'll see in picture 5 that that hole is open in the dryer. There isn't any refrigerant leak when it's open.
Research indicates that the "stud" receiver opening is inclusive to most 911 receiver/dryers. Must be some sort of temperature sensor/switch then.
After more research... According to BEHR that is a mounting accommodation for a their "thermo Fan Switch". Switch apparently used to bring on additional, auxillary, condensor fan speed/capability should the refrigerant in liquid state arriving at the recieevr/dryer be to hot for adequate system performance. Last edited by wwest; 04-22-2013 at 03:46 PM.. |
Scott,
Here is an old thread: HELP NEED! AC/Dryer Switch See Picture. The drier has a blind hole; female thread. Blind hole means it has a bottom, not through into the drier, so no refrigerant will escape. On some variations of the systems in the 70's there was this "temperature" switch. I have yet to find the actual schematic, however normally ac circuits for this type of switch would either turn off the compressor clutch if the temperature at the drier got too high, or turn on a the front condenser blower. Your hose connections, 2 90's at the drier normally indicate no front condenser, however you might have one, just take a look underneath the front nose. If you don't have a front condenser hence no blower up there so the switch would turn off the compressor. There was never any "speed capability" on the 911/912/930. Front condenser blower motor speeds (2) came about with the 964. You could simply follow the wire harness and see where it leads. If the switch, logically, turns off the compressor when the temps get too high in the system, then having it off the drier would never provide its intention. You have original hoses. They leak. I'd replace them with barrier hoses and I'd incorporate a low high pressure switch into the hose between the compressor and deck lid condenser. Lot's of other stuff to consider: Read the MR. ICE PROJECT |
Been here a while
Thanks for the education....
Thanks.
I've read thru your Mr Ice project. If I were keeping the car I'd consider upgrading/fixing the A/C so it works better than it does. I just wanted confirmation that putting the switch in the dryer wasn't going to hurt anything and it appears that is the case.
Dear fellow-peer PP readers. You know what is going to happen to this thead! lol.
If the switch, logically, turns off the compressor when the temps get too high in the system, then having it off the drier would never provide its intention. Quote:
You have original hoses. They leak. Quote:
I'd replace them with barrier hoses and I'd incorporate a low high pressure switch into the hose between the compressor and deck lid condenser. That's not what my sentence above says and I don't recall posting anything concisely as you have twisted. But if you want to twist it Wwest it's gonna hurt ya, lol. |
Banned
Waste of time here at this point. Im out of here
Member 911 Anonymous
summer is coming
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
LOL... If the old hoses didn't leak, barrier hoses would not have been designed for R134 cars. In fact, the last study that I saw cited actually claimed 7 times as much loss. While this might be negligible over a few feet if hose in must applications, it us significant when your car has over 40 feet of hose like most 911s. Barrier hose seems an obvious place to start when upgrading the AC to R134 in these cars. It makes sense to upgrade to R134 and barrier hose "while you are in there" if you are replacing other parts that require evacuating the system.
Caveman Hammer Mechanic
Sweet Jeebus,
This thread, like all the other A/C threads devolves to a, my pet turd is cuter than yours, because mine came from a unicorn. News flash if you cannot drive a rear engined car because its too hot outside, borrow your wife's Honda. Roll down the window, it has 2 or more benefits, 1-you an hear the sweet SSI music more clearly, 2-it will help the car be the same as the outside ambient temperature, if that's too hot for your delicate sensibilities, refer back to wife's Honda comment. I usually read all the tech stuff, because I usually learn something, even if its not in my area of interest, but this is way over the top, going back to the Yugo forums, far less drama. eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
West
If you recharged every 2 years...you did have a "leak problem"... My R134a system with barrier hoses has never needed recharging. Click Even a Yugo has working A/C. If having defective, non functioning equipment on your 911...or removing equipment because you cannot get it to operate...sounds like a Yugo is exactly what you need. Advice to park a 911 when it is hot out...in favor of a Honda seems rather counterproductive to hearing "sweet SSI music." Last edited by fintstone; 04-24-2013 at 09:37 AM.. |
http://www.epa.gov/ozone/title6/609/technicians/retrguid.html |
