about to replace my starter. not too hard right?
guys,
My car wouldn't start after sitting idling for a few minutes at costco gas station. nothing happened when I turned the ignition switch. my starter is dying. ![]() I bought a high torque starter to put in my 81 euro SC. I also bought the "piggy back" terminal splitter and 4 new 10mm washers. I jacked up my car and placed the passenger's front and rear wheels on 4.5'' blocks of wood. I plan on removing the heater hose first before removing the starter. Isn't it guys? Am i missing anything? Seriously i am a lillte worried. For some reason I m a little nervous. Probably lack of confidence and I have to be under the car. ![]() It is not a difficult job to tackle right guys? thanks
French Import
Here is all you need to know...Pelican Technical Article: 911 Starter Installation
Enjoy and report back with pictures when you are done!
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Don't forget to disconnect the battery before you slide under it.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Go-Kart Mozart
A long 10mm Allen socket for your 3/8ths ratchet will help make the job go faster. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
Not difficult but if those are the original nuts you may find it difficult to get sufficient leverage to break them loose. A little penetrant will help if you can see where you are aiming.
Walt 82SC 3.0 81SC 3.6 |
Air Medal or two
You just might run a OO wire to it whilest there....tie a string to the old one as you pull it out,,,then you have help snaking it back in
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Snap a picture with your phone so you remember the wire configuration... I had good luck removing mine pay using penetrant oil, then tightening slightly, then loosening... A trick I picked up from this board when I removed my heat exchangers.... And extensions, yes....
J 911 SC - 1980 911 S - 1977 |
