86FlatSix
DIY - How to remove/install dashboard and rear bumper on an 86
I acquired a few month's ago a decent dash and a euro bumper and need help on how to remove/install dashboard and rear bumper on my 86.
I. Dashboard - How many bolts does it have to take out the dashboard? What are the parts needed to take out to access these bolts (e.g. gauges, access the front trunk). II. Rear bumper - Aside from the side bolts hidden beneath the bellows and the bumper shock bolts hidden under the impact strips are there other bolts that I need to look for to remove the rear bumper? Your inputs/tips/tricks will be highly appreciated. Thanks
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
Senior Advisor
dashboard will require the windshield first, i think, they changed it in the later years. don't forget the wiring in the rear bumper other than that pretty strate forward
08 Cayenne Turbo |
86FlatSix
I was told that the windshields are no longer required to be taken out on 86-onwards, please validate. thanks JQ
Senior Advisor
i don't know the exact years, sorry
08 Cayenne Turbo |
ROW '78 911 Targa
One piece defroster vent across the front or 2 defroster vents is the determining factor. (I think)
if one piece, winshield can stay in. (Again, I think)
You'll need to disconnect the lights in the bumperettes. Unbolt them first from the inside then pull apart the connectors. Bumper is pretty straightforward. I had to wiggle the bolts from the rubber accordion trim pieces on the side. That was the only tricky part.
'84 Carrera (recently sold )'67 MB 250SL A few Italian motorcycles ......and a minivan for the crew |
Pre Registered
There is no need (or benefit) to remove the windshield on an '86 or later 911 to replace the dash.
More detailed instructions here. Tim |
86FlatSix
Need help on rear bumper removal
1. Removed 2 small bolt of the accordion bellows 2. Removed 2 big bolts of the bumper shocks Bumper is moving but wouldnt budge. Tried to pluck the accordion bellows so the screw thred attached to it would free up the bumper but isnt budging. Do i need to remove the remaining 2 bolts on the accordion bellows? I only removed 2 which is attached to the bumpers, please help before i lose my natural light inside the garage ![]() 2 big bolts of the bumper shock ![]() 2 small bolts of the accordion bellows
86FlatSix
Pls disregard i figred it out. I had to pry on the accordion bellows. Congratulations to me on my first bumper DIY
86FlatSix
Finally i was able to mount it! Whew!
86FlatSix
Tested the illumination of the license plate lights since the euro pads are far apart from the US pads. Looks like my plates are still readable, right? Do I need to upgrade and try some bolts with LED?
Absolutely awesome.
I have all the parts for my euro bumper conversion - except the rub strips that include the small rear reflectors. I have been looking everywhere for those. I am jealous!! Nice work!!
- A pile of British stuff - A growing pile of German stuff ... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....) |
86FlatSix
86FlatSix
Before I install the dashboard I bought a few months ago, I noticed there were some screw studs and plastic snap clips missing.
Based on the photo, I wanted to know more or less how many screw/studs (999-591-344-02-OEM), plastic snap clip (999-591-310-40-OEM) and receptor do I need to order from the host. Thanks ![]() ![]()
Looks good. LEDs would probably be better to light up the area but will definitely not feel period correct. Personally I would go LED.
DD - 2011 VW MK6 GTI - Candy White Currently seeking a 911 Carrera or SC |
