-   -   R-12 to R-134a parts. (http://forums.pelicanparts.com/porsche-911-technical-forum/756307-r-12-r-134a-parts.html)
wwest 06-19-2013 09:12 AM
Maybe I, we, have missed something, what if the "non-barrier" hose design is such that really does serve as a HIGH PRESSURE relief "valve"...?
What if the refrigerant only "permeates" completely through the inner liner as pressures grow higher and higher. Now, rather than have those pressures "build up" over time between the hose layers the outer layer "bleeds". The outer layer must be strong enough to prevent bulging/ballooning so absent the bleed off pin holes the result might well be EXPLOSIVE.
So, what might be the permeation rate, through and through, of the inner liner north of, say, 350 PSI..?
wwest 06-19-2013 09:18 AM
Hmmm....
Maybe like the "soaker" hose we have in the garden, hooked up to the low pressure artisian well it just suffices, barely. Hooked up to "city" water it FLOODs the garden in short order.
brads911sc 06-19-2013 09:19 AM
Interesting.
Sounds like you have some testing to do.
After you post your video showing pressures increase immediately after shut down... and your video showing a meaningful drop in pressures at variaus RPMs with and without SPAL fans, you can test your 350 psi hose theory and post a video there. Will be interesting information... Good luck with your testing.
Now kindly drop off all AC threads until you have concluded your testing and have your videos.
wwest 06-19-2013 09:24 AM
Originally Posted by brads911sc (Post 7506291)
Prove your theory. Post a video!!
What is left to prove with a video at this point..? Kuehl (GTI) is in complete agreement with me that only extreme pressures result in our "non-barrier" hose leaking.
The chief naysayer is now left with no clothes...
brads911sc 06-19-2013 09:26 AM
Lol wwest lol
The question to prove isnt whether the pin holes exist (although that would be good too). Its at what pressure do they vent and does our car get to that pressure so often to where everyone would think that their car is slowly leaking through the hoses...
Post the video
The problem with your theory is that therre are those of us who dont add refrigerant for years... which means that venting pressure is not reached... with or without SPAL fans and switches LOL...
the other evidence Id offer is that I once had a defective guage and blew a hole in a deck condenser. You would think at pressures that great that it would have vented.
think WWEST Think. Use that logic.
the chief naysayer is now left with no clothes...
wwest 06-19-2013 09:43 AM
Originally Posted by brads911sc (Post 7506330)
Interesting.
Not at all...Unless you're now willing to despute the GTI(Kuehl..?) statements
If, at this point, you do not see the light at the end of this tunnel then YOU need to purchase some night vision goggles.
The air-cooled engine Porsche of the 90's period have a temperature sensing probe in the air intake duct for the engine compartment cabin heating fan. If, during engine operation, the sensor detects a temperature north of 75C that fan is powered for HIGH speed. to provide additional engine cooling. Additionally there is a 20 minute time delay that is enabled upon engine shutdown should the probe indicate a temperature above 30C. Subsequently, if the probe temperature rises above 70C during that 20 minute period the fan will be enabled for "after-run" engine cooling.
If you are of the belief that our Porsche's do not suffer from the same problem, after-run HEAT rise, then no one, nothing will be of help convincing you otherwise.
Regardless, I still plan to do the video, but at my own time and convience.
The Pelican tech note by Bob Tindel wasn't convincing enough for you?
Sure...NO chance. I never drop out of a poker game with a SUREFIRE winning hand.
brads911sc 06-19-2013 09:50 AM
So basically no proof to your theories (videos) are coming. You have holes all through your theories. Logic has departed your brain. His site doesnt answer the fundamental questions. Sounds like you already backed out because EVERY poster in the last 3 threads was a naysayer. You lose. Game over.
wwest 06-19-2013 10:05 AM
As I said, I'll still do the video but with less urgency since GTI (Kuehl?) and I are now in pretty much full agreement.
brads911sc 06-19-2013 10:19 AM
You should have said that 2 years ago. lol
Im sure he can hook you up with a great Kuehl kit that will make you cold LOL
Still doesnt really answer any of the questions... like why some of us had refrigerant leak with old hose and no leaks with new hose... but you dont have a brain so its futile.
wwest 06-19-2013 10:26 AM
NEW hoses do not have the EXTREME PRESSURE relief design as did the old hoses. So absent the use of some other pressure limiting measures when converting to the new hoses you are simply moving toward finding the next next weakest link...the compressor shaft seal...?
Unless, as the EPA and GTI suggests, you use the binary pressure sensor to LIMIT high side pressures.
brads911sc 06-19-2013 10:31 AM
Interesting theory. Would probably be worth some testing.
Bob Kontak 06-19-2013 12:01 PM
Switches and fans have value. System safety if way high pressure and cooling for reducing pressures. End all and be all - nah. Make sense, hell yes.
All this arguing and name calling, marketing genius vs good AC tech, cow patty, no beef, ass hat, etc...............
This seems to capture the rub stated by Silber:
"It is claimed that somehow the high side stays isolated from the low side after this shut-down period, and that high side pressures continue to rise due to PV=nRT. This is the unproven and unfounded claim that wwest continues to make"
I say if theory is not verified, wwest mans up and offers an apology. If proven, naysayers apologize and pool funds to buy wwest a set of carbon fiber/billet trinary switches (four sets of course) and SPAL fans custom crafted by hand by Kuehl.
Now who was supposed to perform the test?
Edit: No apology for the theory needed but one, perhaps, for being so stinkin' belligerent. You could just own it and that alone will set you freeeeeeeeeeee!!
wwest 06-19-2013 01:35 PM
I am supposed to perform the test, as previously agreed. But in the meantime I decided to convert my 88 to the trinary switch so I could power the fans using a more standard, more current standard, method.
The relatively high open/closing operating pressures of the R-134a pressure switches vs the legacy R-12 pressures concerned me. So I went looking for a trinary pressure switch more in line with R-12 systems.
Found the 35899 on the GM site(***1) and Google cross-referenced it to the Red Dot 71R7500. I have one on order, Amazon. As soon as it arrives I'll schedule the car for salvage/recharge.
It's hard to be overly concerned about the video scheduling since I already know the outcome. In the previous test my probe thermometer digital readout rose from a stable operating temperature of 120F to 150F within 1 or 2 minutes of engine shutdown. How could that not mean that the high side pressure rose AFTER the compressor stopped running.
And that was with the OAT at 57F and overcast skies.
But again, I had done my very best to be sure the evaporator core was throughly COLD-SOAKED just prior to ignition off. So if the TXV wasn't fully closed it was within an RCH.
***1: http://www.e38.org/pparish/gm-rp.htm
Bob Kontak 06-19-2013 01:51 PM
It may have to do with that fancy gas expansion formula Silber stated. I surely don't know.
It may not be linear. Temp rises post shut-off - does "trapped" gas pressure have to react in the same lock step manner? Maybe not? If it does then it would make the transition from high to low side a little quicker. (e.g., while chowing down on ribs)
brads911sc 06-19-2013 01:55 PM
That was my point. The temp rise doesnt by itself prove that pressures rise.
That was the purpose of the video. The equalization of high-low pressures could occur so fast that it would still drop even with a temp rise. The length of hose could also factor into this equation.
I wouldnt make assumptions in this regard... this theory needs proof.
SilberUrS6 06-19-2013 02:02 PM
The answer is if the TEV actually isolates the system by being all the way closed. The professionals say "NAY!", while wwest claims otherwise, with no proof. If the two sides of the compressor are not completely isolated by a gas-tight seal, then high-side pressure will bleed to the low side. I have already done the calculation as to pressure rise due to a temperature increase of 30 degrees F. This assumes that valve to be all the way closed. If the valve is not closed, then pressure will immediately start going down before the temp of the rear condenser rises. Then, as the condenser is heated, the pressure equalization *rate* will slow, due to increasing tmeperature of the components. The effect of an open valve, no matter how small the opening, is an effective increase in system volume. Since pressure and volume are on one side of the equation, and temperature on the other, you'd need a LOT of temperature increase to increase the pressure if the volume is increasing at the same time.
If I did some differential multivariate calculus on the system, I might be able to roughly determine the potential pressure rise, or at least describe the equation for its rate of change. But just by inspection, I can see that there are no temperatures outside of the exhaust manifold that can raise the temperature enough to cause a high side rise like the one wwest would have us believe is happening.
Bob Kontak 06-19-2013 02:28 PM
This I don't understand from a layman's viewpoint. If molecules are agitated by heat, and there is an orifice open to the other side why not haul ass faster over there?
You know, I would help you out on this but it has been so damned long since Newton and I invented calculus (we called it the Big C) that I simply have forgotten most of it.
Wish you had an idea of what it was like to hang out with that dude. OMG. NO - I MEAN, ABSOLUTELY NO tang. Just inventin' and thinkin' stuff up - like all the time. No brush discussions, no nuttin'.
Real rough passage for me.
http://forums.pelicanparts.com/uploa...1371680852.jpg
wwest 06-19-2013 02:35 PM
Then tell us all, please, pretty PLEASE. But if the rate of rise is non-linear we may need the caculation for a rise from 120F to 155F....
If the volume is increasing at the "same" rate cognizant with the rise in temperature/pressure. That's assuming the TXV isn't "closed".
Again, it took less than 2 minutes for the temperature probe to rise from 120F to 155F. It remained at 155F long enough for my patience to wear thin, ~5 minutes.'
IMO that could NOT happen if the TXV were not fully closed or at least mostly so.
Okay, my apologies, when I type "800F ?" or "1000F ?" I am in effect questioning whether or not those values might be valid. It begins to appear that the actual limit for through and through permeation might be 350 PSI or even 450 PSI. Both of those values are taken from currently available pressure relief valves.
wwest 06-19-2013 02:44 PM
Second page, left column, "TXV seat leak"
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&ved =0CCwQFjAA&url=http%3A%2F%2Fwww.emersonclimate.com %2FDocuments%2FFlowControls%2FPDF%2520resources%2F 2008FC-21Troubleshooting-TXV.pdf&ei=mTLCUYrhC4jviQL4-IHQBw&usg=AFQjCNGVpsnbwzYRrnXNBf9_hhV3Fgddew
Or simply Google:
Expansion valve seat leak
SilberUrS6 06-19-2013 03:21 PM
Yes, this is part of the pressure change rate equation. You have to solve for one variable, then solve for another, then finally we can get an equation that tells us how the rate will change over time. Hotter and higher pressure? Higher flow through the orifice. But describing all that would actually be quite complicated. And really, let's focus on the one thing that seems to be the sticking point: That TEV.
Open, even a little? No pressure rise. Closed or blocked? Pressure rise.
I refuse to accept the assumption that the TEV is completely closed. And for a simple reason - the compressor works like a vacuum pump. If the valve were all the way closed, then the low side could drop to 0psi. And quickly. But it doesn't. Even in a system not controlled by a pressure switch. That material has to be coming from somewhere, and the TEV is really the only answer.
