3.2 base idle question. How many turns?
I have to replace the stripped Idle adjustment screw in my 84 3.2. I would like to know what the base setting setting is, how many turns in or out to start from when I put the new screw in.
I have just installed the SW Chip and will be following his instruction re B and C port jumping and setting to 880 instead of 800rpm. Just want to know where to start from.
PK
Old 07-16-2013, 03:39 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Just fit it in then make adjustments as needed, you will need to do it again after she is nice and warm to verify base idle is set correctly.
'85 Carrera Targa
PCA/POC
Old 07-16-2013, 09:18 PM
