Timing for 73 2.4 CIS with Pertronix
Just a question for all. I am getting ready to do a Pertronix swap in my 73 T 2.4L CIS... I did a search but didn't find anything as far as what is the correct timing to set this to. Engine is otherwise stock to my knowledge.
Thanks!
Old 09-17-2013, 07:57 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Wouldn't you want to set it at factory timing specs with a timing light?
1981 911SC Targa
Old 09-17-2013, 08:18 AM
Rescuer of old cars
Arne2's Avatar
Bob is correct. The Pertronix is simply a different method to trigger the coil. The timing should be the same as with any other ignition.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 09-17-2013, 09:27 AM
Fair enough, but what is factory timing spec?
Old 09-17-2013, 01:18 PM
5 degrees ATDC. Your crankshaft pulley should have a TDC mark and the 5 degree ATDC should be the mark just to the left.
Old 09-17-2013, 05:55 PM
Peter Zimmermann's Avatar
Originally Posted by stlrj View Post
5 degrees ATDC. Your crankshaft pulley should have a TDC (aka Z1) mark and the 5 degree ATDC should be the mark just to the left (counterclockwise).
Set at 900 rpm (warm idle).
Keep the Shiny Side UP!
Pete Z.
Old 09-17-2013, 06:15 PM
Vacuum line connected.
Old 09-17-2013, 06:20 PM
vacuum line connected.
bingo!
Pete Z.
Old 09-17-2013, 06:21 PM
I have a pertronix in my 1973 and it works well. Been in there for 7 years or so and needs no maintenance.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 09-17-2013, 08:21 PM
Thanks, all good info!
Old 09-20-2013, 01:57 PM
