Always Be Fixing Cars
The hose portion of the oil tank to thermostat line has been replaced on my car, and was leaking. Cheap looking hose clamps were used. Anyone know where to get some 7/8" high temp oil hose? Is this the type of thing they have at local autoparts? Looks like Elephant racing has what I'm looking for but it'd be nice to find it retail. http://www.elephantracing.com/oilhandling/hoseends/911hoseends.htm
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 11-02-2013, 05:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #181 (permalink)
Registered Loser
R-mm, Have you given any thought of doing what Smoove did and removing the rods and replacing the rod bearings and rod bolts?
How much was that gasket kit?
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320
Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180
Old 11-02-2013, 06:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #182 (permalink)
I'm presently re-agonizing over the whole piston/cylinder situation. I measured the ring lands to ring clearance on the one piston I removed from its bore: perfect. Going to get a ring spreader tomorrow and measure the gap. If they're in spec... I really want to do as little as possible to the pistons. Honestly, even cleaning the carbon off the pistons I'm leaving in the bores has got me spooked. How do I know I'm not going to trap a little piece of carbon agains the bore? I actually hadn't even realized that Smoove did that until I re-read his thread and see the conrods clearly not in place. I don't plan on touching them.
I'll PM you on the gasket kit.
Old 11-02-2013, 06:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #183 (permalink)
Straight shooter
Lapkritis's Avatar
I think you would be better off cleaning the carbon from pistons, ringlands and rings. I would... sparkly clean and reassemble.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 11-02-2013, 07:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #184 (permalink)
This feels right. I'm avoiding it because I just don't know what the right move is after I've taken the rings off. I'm also slightly afraid of the metallurgy of the KS pistons and don't want to damage anything.
A. Reassemble with existing rings if in spec? Is there anything wrong with taking the rings on and off without honing?
B. Find a Porsche familiar machine shop to hone the Alusils and re-ring? With which rings? PET lists 930 103 986 01 as the rings for KS. PP does have these listed but they appear to be $70/set = $420!? The Goetze's sold on PP are 930103 986 00, listed as the Mahle rings.
I could really use some wisdom on this one.
Smoove which rings did you use?
Old 11-02-2013, 08:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #185 (permalink)
Smoove1010
Smoove1010's Avatar
Re-using my rings wasn't an option, I used the Goetze after spending hours reading epic piston/cylinder/rings threads that went back 11 years! They seemed to break in quickly, no detectable oil consumption in 500 miles.
Longevity is the question. I expect to put 1,000 to 2,000 miles/year on my car, so if I need to re-visit this in 5 years, it's OK with me and worth the gamble.
I did correspond with a PP rep on this decision - I got this response to my question about the availability of alusil-appropriate rings:
These are Goetze rings, Porsche OEM, the standard replacement rings for 911s for many years. There are different dimension for the different piston/cylinder sets, to wit:
Mahle : Piston Ring Set (95mm-1.5 X 1.75 X 4.0mm)
K-S (Alusil): Piston Ring Set (95mm-1.5 X 1.75 X 3.5mm)--this is the part number you referenced, 930-103-986-00-M42.
AFAIK, there is no difference in the material they are made from.
That said, if you haven't seen it already, you may want to consider Wayne's opinion and advise regarding honing Alusil cylinders, and reringing them. You can read it here:
How to Rebuild and Modify Porsche 911 Engines, 1966-1989 - Wayne R. Dempsey - Google Books
This caused me to doubt whether the more expensive rings would be of any benefit or if the dimensions were correct. I'd have been more comfortable with something more definitive, but decided ultimately to join the many Pelicans who've ringed their Alusils with Goetze rings. If it starts chugging smoke, there will be another project thread in my future.
GK
Old 11-03-2013, 06:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #186 (permalink)
Thanks for the response Smoove. I read that entire thread last night and came away with the feeling that the Goetze ring are indeed suitable for Alusil and that the right type of silicone paste honing is appropriate.
Here's what I found this morning:
Piston ring end and side gaps are excellent, well within spec. .4mm end gaps, didn't write down side gaps but they were practically "as installed" per Bently. So, the rings are not the issue. I don't have a mic large enough to measure the piston itself nor an inside mic/bore gauge.
The question on my mind is should I take steps to restore the x-hatching and if so who should I send the cyls to? I suppose I could holler at Verden tool. I'll likely also call EBS who have supplied me with parts.
On the left you can see what four of my cyls look like - great shape but no x hatching is visible. On the right is what two cyls look like, x-hatching is visible.
Piston With Cross Hatching visible (2/6 look like this)
Cyl without Cross Hatching visible (4/6 look like this)
Old 11-03-2013, 08:09 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #187 (permalink)
KTL KTL is online now
Schleprock
KTL's Avatar
Yep I use an old dilavar head stud as a chaser, since it's garbage anyway. The length-wise cut in the threads is similar to how a thread tap works. The typical tap has four sides with cutting teeth and the gaps between the sides are there to allow the chips to collect as the threads are cut, w/out interfering with the cutting.
When you use an already threaded part with a slot cut in it, might as well cut multiple slots to make it most effective, you are basically accomplishing the same thing. But since the slots are rather small ( I use a Dremel cutoff wheel), they can clog up pretty fast if the hole you're cleaning is full of a lot of crud. I would NOT use an actual thread tap to clean the threads. Using a tap often will loosen the fit of the threads because a common tap has square teeth on it. The square teeth alter the taper/cut of machined threads.
This is one reason why Henry's Supertec studs recommend using a thread forming tap to clean the threads in the case. A thread forming tap actually distorts the material being tapped to make the threads, more than it actually cuts the threads.
McMaster-Carr
So the thread forming tap is a nice tight fit to cut the junk out of the threads. But not absolutely needed. A slotted old dilavar works great.
I'm of the camp that says don't reuse the piston pin clips. They are very inexpensive so why not just replace them and have no concerns. You never know if you over-stressed a clip when prying it out and thereby reduced some of its spring effect. Agreed a lost clip can have serious results when the pin migrates partly out of the rod. Better to be safe than sorry when it comes to a really cheap fastener that has a critical role.
Those oil cooler seals are good ones. They're brown viton which is OK. Viton O-Rings The silicone ones are the orange/red type that are risky. Over time the silicone breaks down and gets hard/brittle.
Collapsible oil return tube seals for the inside of the standard steel OEM style tubes are part number 999.777.113.41 Pelican Parts - Product Information: 999-707-113-41-M260
I agree since you already removed the pistons from the cyls, might as well clean them up. Certainly can't hurt. Solvents like carb cleaner work OK but they stink bad, evaporate fast and are bad for your health. I soak them in WD40 for a long time (days) and you can easily scrape the crud right off. Or you can buy a gallon of Berryman parts cleaner at your local auto parts store. Its a gallon can like latex paint & has a dipping tray inside to allow you to pull the parts out w/out having to go on a undersea adventure to fish them out. Drop a piston in there, close the lid (this stuff stinks bad too) and let it sit overnight or longer. Carbon just falls right off.
Kevin L
'86 Carrera "Larry"
Old 11-03-2013, 08:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #188 (permalink)
Thanks Kevin. I was in Autozone today looking at the Berryman gallon tub - it did say that Alum should be exposed for NO MORE THAN 4 HOURS (their caps) and that iron should be treated with penetrating oil after exposure. I suppose I could rig up a way to to only expose the tops of the pistons to the solution. My understanding is that the skirts are iron ferrocoated but the piston crown are just plain cast alum?
To be clear - I actually only took one piston free of its bore and that was an accident. I suppose the advice I'm getting is to free them all and clean them right.
Any comment on the x-hatching?
Old 11-03-2013, 09:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #189 (permalink)
Straight shooter
Lapkritis's Avatar
If you are moving forward with piston cleaning then my last recommendation would be to have the domes ceramic coated aka thermal barrier coated. Many options available and proven results. Seems to be a great idea on our air- cooled engines.
Old 11-03-2013, 09:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #190 (permalink)
Smoove1010
Smoove1010's Avatar
My honed cylinders had no additional cross-hatch after the honing process. I was surprised at how smooth they looked! If anything, they looked cleaner. My instructions were to scrub them in hot water and detergent with a scrub brush (not a scotch-brite) before installing. I had my doubts about new rings seating against the smooth cylinder walls, but seat they did.
There's a pic of cylinder 5 at the bottom of this post - you can see that it's really pretty shiny.
87 Drop Top - Drop-n-Top End
My old rings were definitely worn out though. The ring gap was outside the spec for used rings, the oil rings were heavily caked with varnish, the ring lands on the pistons were very dirty. Verden cleaned them up nicely (as you can see in that same post.)
Old 11-03-2013, 03:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #191 (permalink)
Thanks for the responses all. This is really helping. These junctures are always difficult places to be and the having a lot of input is a great asset. I hope to be able to give this back to others soon.
I have the pistons upside down in a bath of WD40 (see top of pic). This feels much safer than simple green (which is semi-alum safe) or chem-dip, ditto. Meanwhile I measured the ring end gaps and found all to be not only in spec, but the vast majority within the "as installed" range given by Bentely. The chrome is in great shape on all rings, no wear visible. Some oil goo, but that should come loose easily. Did notice that all rings are marked either "GOE 5 "or "GOE CRO" (i think its CRO might have been something else - this was the oil ring), suggesting to me that they are Goetze's, but obviously chrome plated. Given this, I am going to go ahead and reuse them.
Was finding that something about the piston geometry made it hard to use them to drive the rings into the bore square so I came up with a semi clever way of using the back side of my calipers to drive them in a consistent depth, in this case about 38mm which is just above the base gasket surface as spec by Bentely.
Head studs and Heads arrive tomorrow!
Old 11-03-2013, 07:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #192 (permalink)
Schleprock
KTL's Avatar
Thanks for the correction on the Berryman stuff. I will check my container, as I have two- a new one and an old one. I believe I used the old nastier one for the recent set of pistons instead of new revised formula that is less nasty, more enviro-friendly stuff.
Don't have any experience with servicing Alusil cylinders so I can't comment there. But I think the history people have shown is good. Since you're reusing the rings, you should not have any problems. If using new rings, then it's advisable to clean the cylinder surface very lightly to remove embedded ring material/knock the glaze off and allow the new rings to seat/seal.
Your way of setting the rings in place to measure gaps is just how I do it. Depth gauge on a dial caliper is just as precise as using a piston. Depth gauge is actually better IMO because you can check your depths all over the place to make sure they're square/not cocked in the cylinder.
Make sure you note the orientation of your rings to reinstall correctly. They have a top/bottom to them.
Kevin L
'86 Carrera "Larry"
Old 11-04-2013, 08:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #193 (permalink)
The Heads are here!
I'll echo what's been said here before - Bob from Anchor Atlantic is top notch. Unbelievably friendly and easy to work with and the end product is art. His insignia, the cylinder number and my last name (!) are stamped on all heads. New Intervalve valves all around. Doubt they looked this good when they were new.
Also got my new lower head studs. Assembly in the house.
One thing that has me a bit stumped is a fairly dumb sounding question: does the 3.2 have a head gasket!? I didn't notice one during teardown and the PET seems to show something that looks like a head gasket (6) but when you look at the parts numbered list, there is no #6!?
Old 11-04-2013, 03:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #194 (permalink)
Schleprock
KTL's Avatar
Pretty heads! Nice personal touch with the Anchor Atlantic logo beneath the combustion chamber.
No head gasket on 3.2. It's a metal-to-metal seal with the head surface and the cylinder top.
That #6 is on the next page of the PET pdf. If you look to the right on the next page, it says gasket #6 is for 930.66 engine which is the 930/911 Turbo engine
Kevin L
'86 Carrera "Larry"
Old 11-05-2013, 10:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #195 (permalink)
French Import
zippy_gg's Avatar
These heads look really bad! I'll take them off your hands! JK.
I bet your oil consumption will decrease, but conversely the mosquito population will increase in your area since the fogging will stop!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 11-05-2013, 04:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #196 (permalink)
Assembly is officially underway. All dilivars have been replaced with steel. Breather area seals have been addressed.
All piston rings measured out perfectly, end and side gaps! I'm going to clean them and put them back on. I'll be getting a dial bore gauge and 4" mic tomorrow so I can measure the bores and pistons themselves, but don't anticipate I'll find much wear. I'd like to use the ultrasonic cleaner to get the crud off the rings - any precautions I need to think about for the chrome on the rings? I'm still new to this machine and don't have a good feel for what it can strip.
Question: any advice on how to drive the G50 input shaft seal in and how deep it goes? I was so excited to try my home depot seal puller that I forgot to measure how deep it gets set. Presuming this one goes in dry on its OD, little but of trans fluid on the ID?
Old 11-05-2013, 08:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #197 (permalink)
Received my 4" mic and dial bore gauge and measured the pistons and cylinders.
For anyone considering measuring their own parts - this is a satisfying job once you get over the confusion of how to use the tools.
After zeroing the mic against a standard, you mark the Pistons and Cylinders at the depth the measurement is to be taken at
In the case of the pistons, you 'simply' measure the skirt. The challenge is of course how to accurately position the mic on a round object. I found that getting the piston at eye level helped.
To measure the cyls with the bore gauge you first need to set zero on the dial indicator. I set my mic @ 3.7403" (corresponding to K&S group 1), stacked up the appropriate feeler things on the bore gauge then rocked it back and forth in the locked mic and set zero to correspond to spec.
From there out its easy. Just rock the gauge back and forth in the bore at the specified depth, and again rotated 90 degrees, and record the deviation from spec shown on the gauge. Reading the dial bore gauge is a breeze compared to the mic.
The good news is that the Ps & Cs have worn uniformly by a few thou and the piston to cylinder clearance is well below the .005" allowable, most are around .003". Based on this I finished cleaning up the pistons, rings and reassembled them and rechecked the ring gaps. They are very healthy. I called it a night but will be cleaning bores and mating surfaces up tomorrow and hopefully installing pistons in the bored without incident!
Separating these guys added A LOT of work to this "top end". I'm glad I had the chance to inspect everything down there and I hope that removing and replacing the rings doesn't lead to any trouble seating. I'm not AN-30 paste honing the bores, just cleaning them well.
Old 11-07-2013, 09:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #198 (permalink)
Nothing to see here... just some Alusil jugs in the kitchen.
Got the mating surfaces all cleaned up and then gave them a very thorough scrub with hot soapy water and a nylon brush. Ditto on the (much harder to clean) cam carriers. I swear my next investment is a blasting cabinet, or I'm jus sending all these parts out for blasting next time. Unbelievably time consuming stuff.
After striking out looking for a pliers type ring compressor in every autoparts store in CT I suppose I'll just order one on Amazon and continue cleaning in the mean time. I really don't want to break a ring as it will trigger a whole new calculus of honing, etc.
Old 11-09-2013, 09:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #199 (permalink)
Smoove1010
Smoove1010's Avatar
I'm not sure blasting is the solution for these parts, but I can sympathize - cleaning in general, and cleaning the cam towers in particular, was a much bigger part of my top end project than I ever anticipated. I stopped short of pulling out the spray bars, but was compulsive about flushing them out thoroughly with solvents, brake cleaner and compressed air.
Good progress - keep that momentum going!
GK
Old 11-10-2013, 06:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #200 (permalink)
