BYantzer's Avatar
3.0 to a 91 c2 engine
Anyone know if this can be done? Just fooling around with the idea.
Brad Yantzer
81 SC
87 944s (dead, burnt it up)
Old 08-11-2002, 06:33 PM
Administrator
Jack Olsen's Avatar
Yes, it can be done.
Old 08-11-2002, 08:04 PM
WydRyd's Avatar
Anything can be done................. for a price
Old 08-11-2002, 08:08 PM
Bill Douglas's Avatar
Why on earth would you want a 3.6 litre C2 engine when you already have a 3.0SC engine?
Bill SCWDP
P.S. A search will provide some good answers.
Old 08-11-2002, 08:43 PM
BYantzer's Avatar
As i said just fooling with the idea. I need some more power and am feeling a bit stock if you know what i mean. going to do a SSI first. Got any other ideas?
Brad Yantzer
81 SC
Old 08-12-2002, 07:42 PM
Formerly bb80sc
Vipergrün's Avatar
In addition to SSI's....
1. 964 grind cams, 9.8:1 Mahle pistons & cylinders, racing valve springs, titanium retainers. If you have a 78-79 3.0, you already
have the larger intakes. Go to the Pelican home page and read the CIS technical article by Noah. I think he got over 200HP at the wheels with this setup.
2. Put the car on a diet.
3. Set the advance to 10-12 degree BTDC (don't exceed max advance at 6K rpms or let her ping).
4. Take off the smog stuff if you have it.
5. Unplug O2 sensor if you have it and adjust CO to 3.5.
All of these things will make a difference, some much more than others. My butt-dyno says changing the advance and doing the O2 sensor made a difference.
cheers
-Brad
80SC
Old 08-12-2002, 08:32 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
I went from a 3.0 to a 3.6 turbo. It FAR outweighs doing all the mods to the 3.0.
Old 08-12-2002, 08:55 PM
