Now I found a way of using a jumper where it is not exposed, very similar to the original fuse block
Use a jumper like this one, of the proper thickness , the originals are about 0.025 inch thick about 22gage, to be safe a 20 gage would be better.
Screw this jumper from the underside of the fuseblock
The fuse block will look like this
Use a nut and a washer to lock the wire
Old 09-22-2013, 09:23 AM
A comparison of the size and height of the original fuseblock and the atc/ato one
Old 09-22-2013, 09:27 AM
Other way to use a jumper that is not exposed
Use a jumper like this one of the proper thickness 22 or 20 gage.
File this part from the upper arrows to the lower arrows.
Put the jumper and should lok like this
Old 09-22-2013, 09:37 AM
I fabricated a jumper with a thickness of 0.035 inch and tried it in the fuseblock.
But I found that there is an interference and it will not close.
This is the jumper I fabricated
Installed looks like this
And I think the interference is in this area
I made a notch and it did not work, I will keep trying to solve this.
Old 09-22-2013, 02:26 PM
Uncertifiable!!!
Uwon's Avatar
Great ideas and great thread guys. I am going to incorporate this in to my RST build.
Evolution of a Carrera RST
Thanks and cheers,
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 09-22-2013, 03:02 PM
Originally Posted by targa44 View Post
Would those not raise the height of the panel and impact closing your cover?
No! The new fuses are the highest item by far, and the cover still (just) closes. See post #42
1982 911SC Wine Red Metallic
OMG I love this car!
Old 09-22-2013, 03:28 PM
Donporfi,
This looks really neat and 0.2 inches width should handle 25A current load!
Did you try it on the top side? If so, you could dispense with the square nuts?
This would look like the most elegant solution, even having to remove the fillets between adjacent screws.
Porwolf,
those Allied/Molex links are only rated at 15A - pity!
Old 09-22-2013, 04:10 PM
porwolf's Avatar
Originally Posted by Algernon View Post
..........Porwolf, those Allied/Molex links are only rated at 15A - pity!
Well, if they would fit you could always double them up, on top of each other.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-22-2013, 07:12 PM
Porwolf,
Grainger has them at 30A
Old 09-22-2013, 08:50 PM
ROW '78 911 Targa
timmy2's Avatar
Link?
Quote de Algernon
Porwolf,
Old 09-22-2013, 09:02 PM
The problem with stacking them up is that you could end with 4 jumpers in one screw. If you check there is one place where four spaces are linked together, that would mean that in the middle two spaces you would have four jumpers. Same problem where there are three linked together.
Old 09-22-2013, 10:01 PM
ROW '78 911 Targa
timmy2's Avatar
Cut these down to suit for as many positions as needed. There is plenty of room in this installation for jumpers that are visible.
600RJ 06 - MARATHON - TERMINAL BLOCK JUMPER, 6WAY, 9 | Newark
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-22-2013, 10:43 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Those are 15A also.
Gary R.
Old 09-23-2013, 04:31 AM
timmy2
Those will not fit this type of fuse block.
The pitch spacing of the fuse block is aprox. 12 mm, the Marathon jumpers have a 9.5mm pitch spacing. And between each three blocks the spacing is different about 11mm.
But keep looking, probably with the help of everybody interested we will find a suitable solution.
Old 09-23-2013, 08:14 AM
GaryR's Avatar
Once someone comes up with a good way to do this they can make up a bunch that are plug-n-play and sell them as kits!
Gary R.
Old 09-23-2013, 08:31 AM
The reason I started this post was not to make money, but help Pelicans make a cheap and easy upgrade to improve reliability of the aging fuse holders, without resorting to expensive kits.
I never expected this level of interest, but if we can collectively find an optimal solution, we all gain!
Old 09-23-2013, 08:42 AM
GaryR's Avatar
Did not mean it any other way, just see an opportunity for one of our talented guys to do something that benefits us all and make a couple dollars too! I for one would pay double for the blocks if they were just an unhook/rehook the wires proposition! We are only talking about a $75(?) kit that would not only update the electrical system but also add spare fuses for things like headlight relays, etc.
Gary R.
Old 09-23-2013, 08:54 AM
porwolf's Avatar
Then take 2 to double up.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-23-2013, 12:10 PM
porwolf's Avatar
donporfi, where did you get your "Made in USA" terminal blocks?
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-23-2013, 12:14 PM
Bought those here
Fuse Blocks - Power
Old 09-23-2013, 03:43 PM
