LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
The suggestion of Algernon to use the bussed fuse blocks probably is the best solution to the jumper problem.
These fuse block come in three fuses blocks, these blocks are riveted to an aluminum strip. We can use one bussed block where needed, just substitute it where it should go.
This is a bussed block for 3 fuses
Old 09-23-2013, 04:06 PM
Just by looking at Algernon picture, probably I would use a three fuse bussed block instead of the regular blocks where the arrows are pointing. But it needs to be investigated a bit further.
Old 09-23-2013, 04:21 PM
porwolf's Avatar
I guess using the 3-circuit bussed blocks in combination with others one would have to remove the original mountig plates and fabricate a new single one that accomodates all the needed fuse blocks.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-23-2013, 05:00 PM
Most probably you will need to change the mounting plate, but that would not be that hard. I do not have a bussed block and therefore I cannot experiment with it.
Old 09-23-2013, 05:27 PM
fred cook's Avatar
I would be concerned that the buss strip is aluminum and not brass or copper.
Old 09-23-2013, 06:27 PM
Fred, the aluminum is the rear support spine or mounting plate, not an electrical conductor.
1982 911SC Wine Red Metallic
OMG I love this car!
Old 09-23-2013, 08:10 PM
Algernon
The buss is aluminum as are the fuse contacts.
Fred
could you please explain why the aluminum is of a concern ?
Old 09-23-2013, 08:25 PM
Formerly known as Syzygy
Canada Kev's Avatar
What's wrong with aluminum? It's actually a better electrical conductor than even copper. If there's a solid mechanical and electrical connection, it shouldn't be an issue at all.
Kevin
Old 09-23-2013, 09:01 PM
Great thread!
Old 09-23-2013, 09:19 PM
ROW '78 911 Targa
timmy2's Avatar
The fear with aluminum wiring is well documented, there is a reason houses shouldn't be wired with it.
The repeated heating and cooling in an imperfect joint without the proper joint compound treatment for aluminum to other metals causes hot spots and possibly a fire if severe enough.
I replaced a lot of it when I was an apprentice. If a house is wired with aluminum wire in the walls, run away!
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Last edited by timmy2; 09-23-2013 at 09:42 PM.. Reason: DUH moment... see following quote!
Old 09-23-2013, 09:35 PM
porwolf's Avatar
Probably not a concern at 12VDC.
Maybe even a bigger concern. For aluminum and another metal connections current is determining its fate not voltage.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-23-2013, 09:39 PM
ROW '78 911 Targa
timmy2's Avatar
Yeah, I was going to edit it, but you beat me to it.
Going to be gone except for your quote in a minute...
Hit the dang send button while in the middle of a thought!
Dennis
Old 09-23-2013, 09:42 PM
Kevin
I think that is not correct, copper is a better conductor than aluminum, but is easily compensated by increasing the cross section of the conductor by aprox 1.6 times.
Old 09-23-2013, 09:54 PM
fred cook's Avatar
aluminum vs copper
Aluminum seems to be more problematic when used for electrical applications. As Timmy2 said above, you don't want a house wired with aluminum because of potential fire hazards. Also, aluminum tends to be pretty soft and could deform when tightening the connections. Another issue could be corrosion between dissimilar metals. Just some things to consider.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 09-24-2013, 02:11 AM
Canada Kev's Avatar
Kevin
Yes, you are correct. I checked and I suppose I had been thinking something else. Brain fart, I guess...
Kevin
Old 09-24-2013, 05:01 AM
Algernon
Oops! I missed that!
Hard to imagine why they did that rather than Nickel-plated brass like on the GEP parts! And then price it higher!
It just occurred to me that the bussed blocks have only 1 screw connection on the 'hot' side, and Porsche use the 'hot' side to take off un-fused power! So it might still be better to use un-bussed blocks and (solid?) jumpers to avoid overcrowding.
Old 09-24-2013, 07:53 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Originally Posted by Algernon View Post
Next time I do this, I will substitute one of these for the left hand group of fuses, to eliminate the 'big red' wire problem. These blocks already have the fuses ganged or 'bussed' together!
CE Auto Electric Supply - Fuse Holders
I wish now I'd seen them before. In fact I might retro-fit one if numbers fit.
Am I off, this looks like the best idea to me, comes in 3,6,9, and 15 position. Not sure how many different hot feeds there are (would assume two, either battery or ignition) but get a block for whatever you need. Not a good idea?
Gary R.
Old 09-24-2013, 08:08 AM
I will order some bussed blocks and see how those would fit.
Algernon thanks for sharing your experience with these fuse blocks.
Old 09-24-2013, 07:36 PM
donporfi,
watch out for above! Alum. and single 'hot' side screw may be not so good after all!
Old 09-24-2013, 07:53 PM
OK, probably return to the copper or brass jumper.
Old 09-24-2013, 08:29 PM
