Bob Harriman's Avatar
Finally got the nerve
I'm actually pretty proud of myself
mask, 3m scratch pad, quarters in the lug holes, spray with SprayMax 2k primer, paint with REM Trim Black, wala!
Bob
Old 10-26-2013, 04:36 PM
Reiver
Reiver's Avatar
Nice job, your car looks great and the wheels just right.
Old 10-26-2013, 05:13 PM
I started redoing my wheels today using rattle cans. I used the paint (Metallic Matte Nickel #7277) for the pedals suggested by manichols. It appears a bit too dark. Any other suggestions? Lastly, is a clear coat or two recommended? Thanks, Gary
Old 02-04-2014, 05:50 PM
MANichols1's Avatar
Robingb - did you use any type of primer? I used a light self etching primer to prep my wheels, from which the Matte Nickel shows up fairly light. Just a thought.
'85 Targa
749R
Old 02-04-2014, 07:12 PM
fuch refinish
thanks for the reply. i used a light green self etch primer. after a few coats of paint i don't think a lighter primer would have had much influence. i will paint the black tomorrow. maybe it will make the pedals look lighter. did you finish with a clear coat? if so, was it a matte clear or a gloss clear?
Old 02-04-2014, 08:52 PM
Maybe someone with more knowledge on RS wheels than me (because I have none) can chime in but I don't think a clear coat is used. As far as primer, I used a two stage spray primer with the activation button on the bottom of the can to activate the epoxy into the primer. Worked great. Four months without a chip.
Bob
Old 02-04-2014, 09:12 PM
joefrantz's Avatar
Rustoleum 7271 Brilliant Silver.
A few examples and discussion here:
Fuchs faux-anodizing - what silver paint?
Joe Frantz
73 911 T
Old 02-04-2014, 09:25 PM
nene's Avatar
I recently purchased some 8x16 from a Pelicanite and decided that now was the time to clean up my wheels and finish them off with an RSR finish...
Well, many weeks later and some frustration because I am sorta-anal, I decided to leave them as per the pictures below. I ended up redoing them several times because of rattle can paint color choices.
I ended up Scotch-Briting the lip, other than that, the petals are of a satin silver finish.
Old 11-05-2017, 09:28 AM
Flojo's Avatar
sweet
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 11-05-2017, 10:12 AM
brainz01's Avatar
Looks good. What paint did you use for the faux anodized?
Sent from my Nexus 6 using Tapatalk
Old 11-05-2017, 12:57 PM
Formerly known as Syzygy
Canada Kev's Avatar
I think he just used a Scotch Bright pad. And then painted the centres black.
They look great!
Kevin
Old 11-05-2017, 01:53 PM
