I am doing a 3.6 conversion on a 84 cab. I got the conversion kit from Steve at instant-G. If anyone is interested I will send pics this week.I think it is tough horsepower to beat for the money. Also a ton of torque. I will admit I do like the responsiveness of a short stroke motor though.
Northern Motorhead
If you need any tips/help , my 3.6 conversion is still fresh in my memory,it's only been three months ... lol
Cheers Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Je Ne Sais Quoi = Targa
'74 Targa lightweight widebody, 3.6 motor, big bars, Speedlines, Sold 2018, '81 SC Targa with 3.2 spoilers, Webers, SSIs, 7&8X16 Fuchs, 911R style exhaust, Had a '71 911S Targa in the 80's, miss it, Had a '61 Roadster in the 70's, miss it also, |
P.s just saw that -big mac and fries motto, lauged so hard i spilled my beer, you owe me a carlsberg! |
my sc went from swift to fast. now chasin cup cars.
1980 911SC #99 track car, 993 3.6, 50 PMO's 2019 Ford F150 da dragger 2015 MB SL400 wifey DD 2008 E93 M3 DD 2007 E60 530 wifey winter beater |
Check out Patrick Motorsport for a conversion flywheel and a beefier clutch. I think they have a kit with everything.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
A Sachs "Power Clutch" is what I used on my Instant G conversion.
My car is @ Aase motors for commissioning, here is a couple things to consider Think about mounting the "puke tank" you will need in the left fender well to eliminate oil mist in the engine compartment. Get yourself the proper race fuel compatible AN-6 sized poly tubed lines with stainless braid to replace the stock SC fuel lines. This thin wall poly tubing will allow both lines back through the tunnel as required. The brake change you desire to due because of the conversion is the "slippery slope", proceed wisely and READ this forum The 3.6 motor will sit lower after install with the IG motor mount, look at the tension on the drain line from the oil tank. I am replacing the 35 year old hose with a longer one removed stock oil lines and had custom oil lines mounted for my 315 tires w/o spacers, again NO 35 year old oil lines to worry about Big ass oil cooler with max air flow
1980 911 - Metzger 3.6L 2016 Cayman S |
old post
ok No one said that, after the conversion you or anyone including me could not wipe off that smile the roar of that 3.6L intoxication
"IGNITION LEFT OF STEERING" Alex Last edited by Alex973; 01-03-2016 at 12:47 PM.. |
non-whiner
Yes, but new question!
"Too much is just enough." |
dwight45
enough
All of this sounds sweet but lets see a few more pics of these converted cars. Come on, you know you want to. We want to see them. I love the concept but have an un-cooperative CFO.
non-whiner
Here you go:
Administrator
My conversion is about 15 years old. Still very happy with the power. Get the car down to 2500 pounds and the engine close to 300 hp and you're at a certifiable sweet spot, at least in this driver's opinion.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Eng-o-neer
I have a 2500 pound M491 coupe with a 3.6. It is glorious. With close-ratio gearing, it is wicked fast. Quite a bit faster to 100mph than my E39 M5. It is so fast that I can't give it full throttle for more than a few seconds on any public street. I'm in the process of making it heavier, slower, and more civilized so that I'll prefer to drive it in more situations.
That said, I my E39 M5 was $18k, and is not depreciating over time. I think in 2016, a 3.6 swap will cost you quite a bit more. In fact, I think you could get an LS3 in there for less money [citation needed] and you wouldn't have to worry about a $15k rebuild 100k-200k miles down the road...I think there are also people getting similar power from 3.2 engines via modern fuel delivery and the tweaking of intake, exhaust, and ignition [citation needed]. Love mine, but I don't think I would spend the money to do it these days. Even 912Es are fun to drive, so be clear on your goals. What would you use this car for 80% of the time? You have the opportunity to buy a 996tt or Corvette and call it a prudent financial move... |
Eng-o-neer
Ah, crap. Got sucked into a thread resurrection.
Automotive Writer/DP
My conversion is about ten years old with no problems. Lots of torque. Miss the engine braking deceleration from a lower mass piston/higher compression 2.8L, but you can have that as well with $$ mods from someone like Jeff Gamroth.
1972 S - Early S Registry #187 1972 T/ST - R Gruppe #51 http://randywells.com http://randywells.com/blog |
Eng-o-neer
What in the world is that intake?
Looks like an attack ship off the shoulder of Orion. |
Varioram (early without script) with JRZ external shock reservoirs mounted on it...
I did a 3.6 964 conversion into my '80SC in 1992. Back then there were no fancy retrofit kits offered anywhere, had to figure everything out and craft the things that were needed myself as well as sort out the wiring. All in all, it wasn't all that difficult!
Lo 23 years later, having used the car as a DD for ten or so years and as a weekend car since then, I could not be more pleased with the outcome. The retrofit resulted in a virtually trouble free car that is as dependable as any DD I've ever owned. Great upgrade from the original '80SC with that trouble prone CIS system! My first step at an upgrade was to install a 3.2 Carrera motor, but it didn't give me the "kick in the butt" that I was hoping for, so a 3.6 it was. The added horsepower is great, but the torque is what rings my bell. A good friend 911 Carrera owner drove my car and came back saying "Man that thing pulls like a V8" To anyone considering a 3.6 upgrade, go for it if you can financially pull it off, you'll never look back!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
I've had 3 different 3.6-3.8 motors in my '76
first was in '94 '93 964 3.6, it was nice but I wanted a little more power ![]() so in '00 '97 3.8 RS vram, this one was too much for the 915 in std form ![]() soo in '04 '95 993 3.6 w/ RS cams, this one is perfect
