Gary
Dropping an engine- Is it really that difficult?
After twenty years of faithful service, I think my old girl (79SC) needs a top end and a clutch. I'm a fairly good amateur mechanic and always thought I would be able to handle the job myself but after reading threads on this forum, I'm not so sure. Is the top end of a Porsche engine that much more complicated than other engines? I would like to maintain the pride one gets from doing it oneself, but I don't want a disaster on my hands.
I watched my Dad drop numerous VW engines. First he would lower the engine as far as he could. Then my brother and I would grab the bumper, lift the rear of the car and roll it forward until it cleared the engine. Does this method not work for a Porsche? I can't justify laying out a bunch of cash for jacks that I'll probably use for one project. Also, someone mentioned special tools needed for timing chain alignment, are they really necessary? Are there any other special tools needed for the job besides the basic tools found in most armature mechanic's toolbox? Thanks for any advice. Gary
9E LUVIN |
Checked out
You and your brother no doubt won the Feats of Strength on every Festivus.
Yes, if you and your brother are strong enough, you could lower the 911 engine as low as possible, and then you guys could lift the car up and over the engine. |
As the big box home improvement ad goes, "You can do it, we can help." I'm in the middle of tear-down with my engine in complete bits. I'm pretty handy but this is a little daunting. I went ahead and tackled it mainly because of this site. I figure I can get just about any question answered here with color pictures and step by step instructions. If it can be done to these cars, someone here has done it. I am blazing no trails here.
As for special tools, I just tore down my engine. I can tell you that you won't need the crow's foot and the special socket for tear-down but you will indeed need them to tighten that big freaking nut upon reassembly. You will also need a way to measure the timing: Z block and dial gage. I just posted in the classifieds and someone loaned me the tools. I have the return box all ready to go in case he needs it back before I finish. I bought a set of stud removers. I also got an engine stand and yoke but a nice big bench would do just as well. I've been picking up this stuff over a long time and none of it was expensive. You will need a good floor jack and jack stands. 911's weigh a bit more than bugs.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Fleabit peanut monkey
Waynes engine book Bruce Anderson's performance handbook Clutch Alignment Pin Inside micrometers or Telescoping gauges with outside micrometers Dial indicator with Z block and interchangeable shaft pins Valve lash adjustment 0.004" blade Feeler gauges for ring gap and end gap Sprocket offset tool. Big Crowsfoot wrench Special cam holding socket Two big honkin 1/2 drive breaker bars Sprocket/layshaft offset measurement tool Depth micrometer or dial calipers that measure depth. Good torque wrench GOOD quality wrenches and sockets - Craftsman or better Loctite 574 Timing light Fuel gauges CO sniffer Long 3mm wrench for AF mixture Ring compressor Two stretch bolts and plastigage for checking one rod bearing Engine yolk Engine stand
1981 911SC Targa |
Gary,
What is your location. Perhaps others are close by to lend a hand/tools? Thor
1978 SC coupe #1834 |
1981 911SC Targa |
Yea, jack stands are not an option (unless you have a lift.)
![]() There are no hand holds for a 911 that a couple of very strong men can use. I use my jack stands all the time. I can't imagine working on a 911 without 4 good jack-stands.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
wannabee wannabee
$99 motorcycle jack was good enough for me. Yes drop the engine first then raise the car up.. I used stacks of wood. Sorry can't help you on the top end department...yet. Excuse the red paint (stupid Chevy mechanic did that).
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) Last edited by WIL84911; 10-10-2013 at 01:57 PM.. |
Gary
Thanks Thor,
I,m in Omaha. Any help would be great. Gary
9E LUVIN |
You are dealing with an engine that is arguably "exotic" given the parts explosion. You are also GROSSLY underestimating the task. I think you and your pal have not a clue of how to pull this off and I am sensing that you will not put the time into required due diligence. You will **** this up, BIG TIME. Guaranteed, unless you change your mindset. Mark my words. Have a nice evening.
1981 911SC Targa |
Dropped mine for the first time this Tuesday which took me 2 hrs start to finish. I lowered mine on to 4x4's and then jacked the car up and slid her out.
looks good , but how did you jack up the car once you dropped the engine ? is there a good spot to jack up with the engine dropped ?
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
I placed my Jack right under where the shift tube exits at the end of the floorpan. I used a 2' block of wood to run along the bottom edge and it went up without issue.
Your method solves this.
El Duderino
Maybe there is a 12 step program.........
However, I see big time disaster in this situation. Won't spring for jack stands and discounts chain/sprocket alignment as if it were fashion. Perhaps cam timing and valve adjustment could also be bypassed. This guy is the the future PO we see other people talking trash about.
1981 911SC Targa Last edited by Bob Kontak; 10-10-2013 at 05:04 PM.. |
Bad LT
No jack stands. No chance.
Ex Porsche Cup car with some boost and stuff. |
Purchase some good jack stands, and a good floor jack. A DIY Porsche owner will always need these. Like, brake jobs, new clutch, ect... Drop the engine-trans as a unit, load it in a trunk or a trailer and take it to a somebody reputable, that does this for their lively hood, what I did when I found broke head studs, and very happy I did. You will save $$ in just the beer it would cost.
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
