1QuickS's Avatar
SWB adjustable spring plates and alignment
I began a new project this weekend; I'm modifying my shortened 911SC spring plates to have a screw adjustor like Sway Away no longer makes. I'm also beginning a four wheel alignment and corner balance using the corner scales and simple string alignment aid I made and will be marketing shortly; more on that later.
I first removed rear shocks and installed my height adjusting rods:
I also disconnected my front sway bar drop links and connected them to the brackets on my inner wheel well:
I adjusted rear ride height while supporting front cross member to avoid corner weight bias:
Made a CAD drawing and templates for modifying the spring plates:
And:
Photo of brackets aligned on spring plates ready for welding:
That's all for today.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 11-10-2013, 04:24 PM
proffighter's Avatar
Nice springplates! I love DIY
Roland
930 Turbo '81 Too many modifications to list
Old 11-11-2013, 12:00 AM
Project Addicted
LOVE these on my '66 912.
Took some grinding of the screw mount and the lug it presses on to make 205's not rub.
I can send pic of the grinding if needed. I can also measure it too.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 11-11-2013, 08:03 AM
1QuickS's Avatar
Hi Jon,
I think I'm good, I checked tire clearance before I removed for the surgery. Running 225/50-15's on 7Rs with spacers.
Paul Abbott
Old 11-11-2013, 10:54 AM
Banned
Now THAT is the understatement of the year!
Old 11-11-2013, 11:02 AM
micheloaks's Avatar
Paul how did these finish up?
Old 04-23-2014, 08:59 AM
1QuickS's Avatar
I installed and adjusted my car using these just fine. I need to make one more iteration in ride height that is beyond the range of adjustment but haven't gotten there yet.
Paul Abbott
Old 04-23-2014, 11:21 AM
micheloaks's Avatar
BTW how are you using the height adjust rods
Old 04-23-2014, 09:29 PM
1QuickS's Avatar
I used the rigid links to adjust ride height and alignment and then installed t-bars and adjusted to just take the load ff the links.
I made the links for use in assembly and other tasks during my build as a convenience to hold the car at ride height while working on it...this is primarily why I had the links in the first place.
Paul Abbott
Old 04-24-2014, 12:19 PM
Project Addicted
Paul, can you provide some details for your mod??
Thickness of ne blocks?
Bolt size and threads?
A PDF of the drawing of the plate for modifications??
I know it's asking a lot be we want to perform this mod on our project car and love the DIY aspect.
Jon
1966 912
1986 944
Old 08-05-2014, 07:50 AM
1QuickS's Avatar
Contact me via m business email and I can get drawings to you. Performance Oriented
Paul Abbott
Old 08-05-2014, 03:39 PM
Walt Fricke's Avatar
Paul - those ride height links look like just the thing for locking the suspension and figuring out the center of gravity.
Old 08-05-2014, 08:30 PM
