SC to Carrera brake conversion questions
I'm putting an entire Carrera brake system on my SC (for race class reasons), and just installed the rear calipers/rotors, a few things:
On the SC the spring for the pad pins don't have this extra retainer that looks like it should lock into something, am I missing something? ![]() The SC hard line in the rear comes out of the bottom of the caliper, the Carrera out of the inside at a 45 degree angle. As my hard lines are 35 years old i'll just buy new ones. I bent up the SC's to fit just to keep the system closed.. The SC hard line mount - ![]() Carrera hard line mount (with temporary SC line mounted)-
Gary R. |
Hey Gary,
I want to do this also on my 82SC.. Assume it's just upgrading to Carrera calipers and hubs, and it bolts up to same strut mounts holes? thanks
1984 Carerra 3.2L - SP911 PCA, SCCA, NASA, ComSport |
I don't see anything in PET about that little clip on the pad spring so unless I hear different i'll order the hard lines tonight.. just odd, it MUST clip to something? I bet I'll just end up clipping it off.
Gary R. |
That's to hold the wire for the brake pad wear sensor. I yanked my sensor off the pads and zip tied the wire out of the way. Don't worry about it on the clip.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
And like everyone else in this thread, I am getting ready to do this too.
![]() My question is about the master cylinder. It is the same?
'17 Cayenne |
Guess the front rotors had to be changed anyway! ![]()
Gary R. |
Yep, thanks Cory. I'm just going to Dremel them off as they are useless to me. I ended up buying all the hard lines as the fronts took some persuasion to get off the rubber lines on the struts.
Gary R. |
Caliper looks great. Did you send them out to be restored or do it yourself?
Tru6 Restoration & Design |
Gary R. |
Registered speed offender
+1 As someone else mentioned... dremel the pad clips to get rid of the wear sensor tabs AND install the rear bias valve. It goes in the trunk near the MC. Also, one can use the SC pads as they are the same size/shape as carrera pads without the provision for sensors.
If you keep looking back, you'll never move forward. http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html |
Gary R. Last edited by GaryR; 02-23-2014 at 06:01 PM.. |
Carrera advantage is in the rotors, bigger heat sink.
I get that part, but I can just toss in the pads I was using in the SC (PFC 97) and go? I just assumed the bigger calipers took bigger pads!
Gary R. |
The front calipers are almost exactly the same between the cars. That 'almost' comes in the form of a spacer between the caliper halves that allows for the use of the thicker carrera rotors. So, if you've already found a favorite pad, you can keep using it after the overhaul.
Brian Starr Alabama Region PCA 1983 911SC/Rebodied as 993 w 3.6 1995 911 C2 (Sold) |
The SC rears aren't especially thermally challlenged, so upgrading just the front calipers/rotors to 3.2 spec could be a good approach for some. Bias won't change, and you wouldn't need the pressure limiting valve at all then.
'77 S with '78 930 power and a few other things. |
To note, I performed this conversion and the only changes I made. Front and rear Calipers and rotors, and rear hard brake lines from a Carrera. I bought new soft lines, pads, and master cylinder from an SC to be thorough. |
They also use the same 20.6mm m/c You are still going to want to run SRF, as these are still very hard working brakes
Absolutely! Just have to figure out what version PFC's i'll be going with once I burn through the rest of my 97's.. Going to the PFC seminar at Speedsport Thursday, hope to get some good input from the rep.
Gary R. |
Part no. ?
