Just ordered a set from my hotel room (Asia vacation).
Cheers.
78 911SC sunroof Coupe (SOLD) 97 328i Convertible |
PM sent
Carmagic.us
All these orders were shipped today. Enjoy the light.
Looking forward to see some pictures. Thanks Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
Brew Master
The only problem I have is dimming the new "bright white" lights. There's very little difference from low to high on the dimmer. Any suggestions? I haven't driven it at night yet to see if it matters much but there is SO much difference in the amount of light that it concerned me a little.
BTW, my brother loved the upgrade and will be buying the classic lights from you. |
Carmagic.us
I got the vintage in my SC and the bright white in the 87 Carrera, and both dim enough to adjust and they don't overpower.
There is also the possibility that the light switch is not working properly for the dimming, however the LED's acting a bit different as the normal bulbs. Please let me know how it looks at night. Thanks Engelbert
Got mine today and look forward to installing them.
All I need now is to find the time.
Ordered them on Sunday and got them on Wednesday.
They are really bright! I noticed the same issue with the dimming.... not much difference between low and high. But this is not a big issue since I always have them on high. |
PM sent.
Scott '86 911 Carrera Coupe, PCA, PBC |
Received mine last week and installed them over the weekend. Easy as pie and I'm very pleased with the results. Thanks!!!!
1978 911 SC Targa 2007 Boxster (sold) |
Carmagic.us
Here is some additional information to make these LED's work best for the early cars.
The early cars have only one bulb for illumination in the Oil Press/Temp. gauge. ![]() See picture below, it's the ome in the middle. ![]() To show what need to be done, I removed the Temp. gauge. ![]() There is a reflector shield for the standard bulb to reflect the light. That little shield need to be just bend down. ![]() There is no need to remove and disassemble the gauge. Just remove the light bulb socket when changing to LED, and use a screwdriver and push the reflector down, before re-install the socket with the new LED. ![]() Cheers Engelbert
I'm very interested in these for my 1970 911T but I'm wondering how you control the current flowing through them. Also, can you divulge which LEDs you use?
UFLYICU
Englebert, you have a pm
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Carmagic.us
Here is the picture of the LED. ![]() Hope this helps. Cheers Engelbert
Thank you, it does help. I just stumbled upon the engineering debate in the 'Ultimate LED Ba7s bulbs for Gauges ala ETarga' thread and was worried about the same issues some of the EE's brought up, being an electronics designer myself. I see your bulbs contain 5 LEDs, which drop all the 14 V, but I'm confused about the value of the surface-mount resistor. Is the code 301 or 10E?
I like the design of these bulbs and I'm very interested in replacing all the bulbs in my gauges, which are beyond dim. You can PM me with prices, details and pay options if you prefer. Hopefully you ship to Canada! Thanks! |
Question, rothaus: Can these LED lights be dimmed to complete darkness or barely visible at night?
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Carmagic.us
Hope this helps Cheers Engelbert
Carmagic.us
The set for the 911 is $36 + $4 s/h Cheers Engelbert
Thank you, Engelbert. I re-read your thread and realized the answers to most of my questions were in the information you already provided. I'm still curious about the value of the resistor but your LEDs obviously work well. Before finding this thread I was planning on making my own LED bulbs but for this price, I can't be bothered!
I'm placing an order very soon. |
Hi Engelbert,
I placed an order for the 'Bright White + 1 Green, 1 Blue' set last night. Did you receive it? Last edited by 911T70; 11-14-2014 at 12:16 PM.. Reason: correction |
Carmagic.us
Thanks Engelbert
