Send a message via AIM to Hcarraro Send a message via Yahoo to Hcarraro
Subscribed
Old 12-01-2014, 06:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
911T70's Avatar
I installed the LEDs and made some measurements last weekend. The LEDs are a huge improvement over the old bulbs but they make the dirt on the inside of the gauges' lenses obvious so I'll have to take them apart and clean them!
The rheostat puts out 0 V when turned fully counter-clockwise. Turning it clockwise, a click can be heard and the voltage jumps to 9.3 V. At fully clockwise, the voltage is 12 V. This is with the engine off so it'll be higher when the car is running. The LEDs come on at approx 7.5 V so they're already pretty bright when the dimmer switches on at 9.3 V. There is some dimming through the range of the rheostat but not much. Still, it's good enough for my needs so I'll leave it alone. If one wanted to increase the dimming range, a PWM circuit would work but I would personally use a power op-amp that scales the output of the dimmer to suit the LEDs.
Old 12-02-2014, 04:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
Carmagic.us
rothaus's Avatar
Thanks for posting you results. I think that confirms that the dimmer in the light switch is not consistent, and depending on the condition it dims different. As an example, the LED's in all my 3 cars (71, 82, and 87) don't turn off complete as yours.
Thanks again
Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 12-03-2014, 04:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
911T70's Avatar
I'm afraid I wasn't very clear - the LEDs start to come on at 7.5v when tested with a variable power supply. In my 1970 911T, the dimmer's voltage range is 9.3 to 12v, so they're pretty bright at the lowest setting. They get a bit brighter as the dimmer is turned clockwise, reaching 12v at the end of its range. This means that they never go off, that they vary between bright and very bright, which is fine for me.
Old 12-03-2014, 06:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
Carmagic.us
rothaus's Avatar
OK, clear now. I also tested the voltage at the dimmer in the 87, that the car which dims the least. With Battery power only, I got 11V at the lowest and 12.1V with the dimmer full open. On this car is not much difference between low and high.
I got a 250 Ohm, 5W dimmer and connected it between the switch and the cable to the instrument lights. With the light switch dimmer full open I can now dim the LED's from complete off to bright, with a nice range.
Here is a video with the additional dimmer.
Cheers
Engelbert
Old 12-05-2014, 03:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
Member 911 Anonymous
DRACO A5OG's Avatar
So is the 5w dimmer a separate component with it's own dial/rheostat?
'85 Carrera Targa
PCA/POC
Old 12-05-2014, 05:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
porwolf's Avatar
Cheers
Engelbert
Looks like this dimmer has its own rheostat separate from the Porsche light switch rheostat, right?
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 12-05-2014, 06:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
Carmagic.us
rothaus's Avatar
Yes, it's a separate dimmer. Like I described in the post above, I connected it between the light switch and the cable that goes to the instrument lights.
Cheers
Engelbert
Old 12-10-2014, 09:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
Carmagic.us
rothaus's Avatar
Correct !
Cheers
Engelbert
Old 12-10-2014, 09:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
DRACO A5OG's Avatar
Do you sell this too? Can you post a pic of how it looks please?
I think your LEDs dim enough on there own, complete black out does not seem necessary at least for me.
'85 Carrera Targa
PCA/POC
Old 12-10-2014, 11:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
Carmagic.us
rothaus's Avatar
There was a lot discussed about dimming, so I gave it a try and it worked great. I did not install the dimmer since I don't need to dim them down that much at this time. I just want to proof that it can be done, in case it's required.
I got the dimmer 250 Ohm, 5W from Didgikey. I can post the detail if needed.
Cheers
Engelbert
Old 12-10-2014, 01:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
Vintage Owner
Jack Stands's Avatar
Perhaps a short wire extension with a fuse and the dimmer in line would be a nice upgrade for the instruments and also protect the instrument light circuit.
Please post the dimmer part number if you could.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 12-10-2014, 03:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
DRACO A5OG's Avatar
Cheers
Engelbert
LOL, funny how we are complaining about dimming the gauge lights down
'85 Carrera Targa
PCA/POC
Old 12-10-2014, 05:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
88 Carrera, Guards Red
azhodge's Avatar
ain't that the damn truth.
Old 12-10-2014, 05:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
porwolf's Avatar
Cheers
Engelbert
Is this the one you got from Digikey?
http://www.jkllamps.com/pdfs/ZDM-01.pdf
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 12-11-2014, 12:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
Neilnaz's Avatar
Hi Porwolf, from the sounds of it Rothaus has just used a 250 Ohm 5W Potentiometer (variable resistor) to drop the volts fed to the illumination line that gangs all the LEDs together. I think I may try this alongside the in-line fuse.
Cheers, Neil
Old 12-11-2014, 07:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
Carmagic.us
rothaus's Avatar
This is the dimmer I used from Didgikey p/n 026TB32R251B1B1 is $8
I was thinking making it in a package with pre-wired and mounting plate, but I think that there would be enough demand. So if someone want to dimm the LED's down like the standard bulbs, this dimmer can be used. You need also a knob, that's another $8 or so.
Hope this helps
Cheers
Engelbert
Old 12-12-2014, 05:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
Neilnaz's Avatar
I did the same using a similar pot of 500 Ohm value. I also installed a 5A fuse in line with the pot. The result is bright to extremely dim from one end to the other of the adjustment. The variation isn't linear with the turning of the knob but it does work really well. There was already a hole in the dash that now has a nice black adjuster - very happy with the LEDs and being able to dim them.
Cheers, Neil
Old 12-13-2014, 01:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
DRACO A5OG's Avatar
Make it stealthy non-intrusive bluetooth adjustable and I am sold :-).
I am just not diggin the idea of a secondary dimmer hardware. I have enough electrical components to worry about. My 2 cents.
'85 Carrera Targa
PCA/POC
Old 12-13-2014, 10:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
porwolf's Avatar
There should be a rather simple electronic solution besides a PWM, to mimic the 500 ohm potentiometer regulating the LED current with the factory 5 ohm rheostat. Any ideas? I will think about some solution also.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 12-13-2014, 02:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
