kodioneill's Avatar
How do I lock the tranmission for torquing the nuts under shift cover
I need to finish rebuilding a 915 with the final nut torque how do I lock the trans without the mainshaft spline tool?
And finally, I had to remove the mainshaft nut after staking (installed bearing backwards) can I reuse it with red loctite? There was some metal left for a small dimple to stake down but not much.
Thanks guys
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 04-22-2014, 12:47 PM
kodioneill's Avatar
Alright, I think the torquing problem is set I'll weld a steel bar to a old clutch disc and drill a hole in it to fasten it to the bell housing.
Still need input on the main shaft nut though.
Thanks as always.
1982 chiffon 911sc
Old 04-22-2014, 02:02 PM
I put it in 2 and 5. I would get a new nut.
Old 04-22-2014, 04:33 PM
