LinkBack | Thread Tools | Rate Thread |
How do I lock the tranmission for torquing the nuts under shift cover
I need to finish rebuilding a 915 with the final nut torque how do I lock the trans without the mainshaft spline tool?
And finally, I had to remove the mainshaft nut after staking (installed bearing backwards) can I reuse it with red loctite? There was some metal left for a small dimple to stake down but not much. Thanks guys
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera Last edited by kodioneill; 04-22-2014 at 01:59 PM.. |
Alright, I think the torquing problem is set I'll weld a steel bar to a old clutch disc and drill a hole in it to fasten it to the bell housing.
Still need input on the main shaft nut though. Thanks as always.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
I put it in 2 and 5. I would get a new nut.
