![]() JR |
Found it, and yes it was just the practice stuff.
Update: building a roll cage Quote:
Steel Conduit Pipe Manufacturers & Supplier ISI marked Punjab India Quote:
http://www.ioportracing.com/faq/rollbar.htm Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 04-21-2014 at 08:20 AM.. |
I remember how I used to think that anything from the factory was good, but then I read about the innovative pressure gauge that they installed on the frame so that the driver could detect the moment it cracked so he could return to the pits. Even the factory was still learning.
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
Max Sluiter
If you think that frame is scary, think about the Le Mans winning (!) Magnesium (!) frame for the 1971 917K.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Max Sluiter
My point is still valid. Yes, there are lighter materials out there, ones that don't need to be welded.
No typo. Some race cars are actually that heavy. JR |
Even if I could get my steel bodied / aluminum bumper 911 up to 155 mph, I have sincere doubts about my chances of survival - even with a steel roll bar.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Why would the rules mandate the weaker ERW (conduit) be used on the heavier +3,500 lbs cars?
I would think that a heavier car would need more strength not less (more strength like DOM or Chrome-Moly). Same reasoning also allowed me to think that a light weight roadster from the early 1900's could get by with a laminated loop/hoop of wood. Although at the time they favored ejection (no seat belts) as the preferred method of accident survival.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 04-21-2014 at 07:00 AM.. |
While you're at it, read up on welding 4130. You have some misconceptions there, also. You might be surprised at what you learn. Understand that 4130 was originally intended to be gas welded. There are advantages to that. Modern welding methods change the nature of a 4130 welded joint and you need to understand what role is played by the type of welding used, the type of filler rod used, the size and shape of the weld filet, the use (or not) of pre- and post-weld heating, etc. etc. It's a complex subject and not well understood by most people, including a lot of welders. JR |
Porsche race cars (like many of that period) were not safe at all. If my memory is any good, they didn't even tell the drivers of the magnesium-framed 917 that they were using that material in the frame, until after the race. The first race car they built with any decent safety was the 962. Even the 956 was a killer. I still remember the day Stefan Bellof died in one. JR |
You can't make blanket statements like they do, about roll cages and their suitablity for cars based on weight. Each sanctioing body will have specific rules and even these may change over time. They may also conflict, in that a cage legal for one race series would not be legal for another, unless changed. If you are building a car for a particular series, the rules will generally specify the minimum sizes and types of tubing to be used and most will have some guidelines on what sort of design is needed. JR Last edited by javadog; 04-21-2014 at 07:27 AM.. Reason: spelling |
Troll Hunter
And I thought it was just a simple question I originally posted….
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
abit off center
All my welded joints are normalized same as we do with fuselage tubing. It takes some time to heat everything back up but really the only way to do it.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Untitled Document You too, Max. ![]() JR |
Just kidding. ![]() I've learned a few things, new week though and it's time to move on.
Porsche used an aluminum roll bar in their 1969 911 GTS. |
Ayo Irpin, Ukraine!
It was also optional on the early STs. Same design as the steel but, in ALU.
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
This 914 makes some repeated use of aluminum.
914-6 GT Troutman Truck Detailed Photos August 8, 2011 Gunnar Racing ![]() Quote:
![]() Quote:
Porsche 904 http://cobraferrariwars.com/porsche-904.html ![]() Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 04-21-2014 at 03:25 PM.. |
Aluminum cages are used often here in Europe, I have a FIA approved HEIGO
![]() Here I posted the document: Looking for ideas and/or pictures of drilled out parts Weight difference is quit big, steel cage is 34kg, same in alu is 18kg Material is AlZnMg 1 F 35, steel would be 460
Roland 930 Turbo '81 Too many modifications to list Last edited by proffighter; 04-21-2014 at 03:11 PM.. |
