Chain fence eating turbo
Aluminum alloy would still break as others have posted. Steel just keeps bending and bending without breaking......to a point.
That depends a lot on the type of aluminum used.
Information Junky
I expect that you are focusing on his sarcasm, and not the more subtle point below that. - "It did help the rollover after all."
That is, putting weight up high does a car no performance favors. Certainly adding stiffness helps, but at what weight penalty? A 911 coupe has plenty of stiffness from the geometry. A targa or Cab uses much more steel down low to come to an acceptable rigidity... which can be improved on. Of course you could make the aluminum thin enough (think a thin band of AL - not tubing) that the strain to failure wouldn't be reached ... but that would be ridiculously thin.(no stiffness) So what's the OP trying to optimize? Strength, stiffness, weight? ...bling? He has a coupe for the fitment. Sounds like he's liking the thought of a no-paint solution, and yet offers "Safety is clearly the issue here." For that, clearly steel is the winner. Side note, people confuse strength with toughness all of the time. ...and then there are issues such as strain to failure and stiffness.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee. ![]() |
I did find one stainless steel roll bar (cage), a non-911 application though.
Is 304 grade stainless steel more brittle than molybdenum steel? Is molybdenum steel more brittle than mild steel? And where does aluminum fit into the spectrum? TigerCage – Bolt-In Roll Cage System TigerCage – Bolt-In Roll Cage System « Ridetech News and Information ![]() Quote:
I am by no means qualified to create such a chart, but if I find one I'll post it. Is the statement below true? Hypothetically...Aluminum Roll cage http://www.jeepforum.com/forum/f12/hypothetically-aluminum-roll-cage-955970/ Quote:
http://www.jeepforum.com/forum/f12/hypothetically-aluminum-roll-cage-955970/index2.html ![]() Quote:
http://forums.rennlist.com/rennforums/964-forum/111229-heigo-rollbar-aluminum-or-steel.html
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 04-19-2014 at 06:36 PM.. |
This 917/10 chassis including rollbar must be a horrible idea then, being all aluminum....
![]() Last edited by LJ851; 04-19-2014 at 06:28 PM.. |
![]() I think it's all a matter of engineering and lifespan of the material. If I were going to race a car for just a few years or just want to make a car safer, it seems aluminum would have a lot of advantages. Longevity and cost is where steel takes the lead, right?
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 04-19-2014 at 06:45 PM.. |
Under the radar
It would be interesting to know the engineering details of the 917 frame. What alloy, temper, welding details, and was the frame heat treated after welding. Some of the 917s crashed. I wander how they fared.
April 6th 1970, EHRA-LESSIN (Germany)
"photographs of Carlos Ghys´ biography, part 22 = «KURT AHRENS»" ![]() ![]() Quote:
http://www.carlosghys.be/html/biography_ahrens.html ![]() Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 04-19-2014 at 07:40 PM.. |
Banned but not out, yet..
Some of the boys forget to close the door after they leave PARF and a cold draft sneaks in along the floor following them.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
A little personal perspective on roll bars and roll cages: Last night I received a call from my son who is racing his Ultra-4 off road racer at Moab, UT at Easter Jeep Safari. My son is a mechanical engineer in his day job, so his racer is properly designed and has the roll cage as well as the front and rear frames constructed out of steel DOM tubing. Anyway, within sight of the finish line he did an end-over-end roll, winding up on the roof! With some assistance from another competitor, the rig was uprighted and he finished the event. After an inspection and topping up fluids, he ran and placed in the next race. Damage is minimal as no tubing is bent, dented, or misaligned. My take on all of this is that we will see and ever increasing use of aluminum and composites in our vehicles going forward, but for those of us modifying and racing our own cars without the services of a well-staffed engineering department, we need to err on the side of safety and strength.
abit off center
Aluminum Roll Bar?
Our cage made for what our car weighs is. 1 1/2 4130 .095 wall tubing only added about 60# to the car and we are still just under 2k total. This tubing is very strong and light weight.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
FWIW: The porsche factory was selling the Tekquipment stainless roll bar for the 996 GT3. A couple people modified these for installation in a G series chassis (1978 SC i believe).
imho, an aluminum bar is not for me. At best its a cool visual accessory
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
I talked to my brother on this topic (an engineer), he said the real weakness in using aluminum is in the welds.
The impurities introduced during the welding process could over time compromise the strength and other qualities of the material. By contrast the 911 aluminum bumpers are not welded anywhere that I know of. Of course some people fill in where the rubber strip is and also fill in other holes, so that may change things for them. All this talk has given me a curious thought; what if someone removing their stock aluminum bumpers in exchange for fiberglass parts attempted to recycle/reuse/modify them as roll bars? For sure it would gobble up lots of interior room and the channel shape would not be as strong as a circular section of the same amount of material (weight). However it would come at an affordable cost - free. I'm never going to try it, as some thoughts just meant to be left as thoughts.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 04-20-2014 at 06:28 PM.. |
A used bumper wouldn't be my first choice...
You could design an aluminum structure with the same strength or stiffness as a steel one, if you used enough material and selected an appropriate diameter and wall thickness. Whether it would be lighter or not is debateable. There's a weldable alloy sold in Japan, 7N01, that has the ability to return to near pre-weld strength through natural aging. It's around 60ksi, give or take. JR |
Thank you javadog for adding some good information.
On another note; I wasn't sure what DOM steel was and how it may differ from mild steel. So I started to look up a few things and found this................ Mild Steel vs DOM | race-deZert Quote:
I don't think there is a sanctioning body on Earth that would permit a roll bar to be made from electrical conduit.
JR |
You know, maybe it was just the mock-up now that I think about it.
It was several years ago, I'll try and find it.
abit off center
Aluminum Roll Bar?
According to NASA rules if using ERW or DOM the tubing has to be larger for the weight vehicle that's why we went with the strongest 4130 seamless tubing and could use 1 1/2 inch which kept the weight down but still offers superior protection. And I'm not sure but they may not even allow ERW any longer?
We used conduit for the cage mockup cheap and easy to work with. Last thing you want to do is waste some expensive tubing.
Max Sluiter
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance Last edited by Flieger; 04-21-2014 at 06:46 AM.. |
