1984 911 Targa - "Sabine"
Skip1's Avatar
Unknown Electrical Connector behind AC drier
Hi guys,
So today I was doing some brake servicing and cleaning inside the wheel wells, and I found this connector tucked behind the AC lines just above the Drier in the front left wheel well. No idea what it is for - thoughts?
Cheers
Skip
1984 (RoW) 911 3.2 Li Carrera - "Sabine"
2011 Cayenne S
Old 04-26-2014, 08:41 AM
brake pad wear sensor?
Sold: 1989 3.2 coupe, 112k miles
Old 04-26-2014, 09:47 AM
Might be the connector to the refrigerant overpressure switch which can be mounted on the drier. Perhaps the drier was replaced with a model that does not have that switch?
Old 04-26-2014, 09:53 AM
I think brake wear sensor too. The center looks a bit odd. Is there a wire stuck in there to short it and kill the light? I've done that before. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 04-26-2014, 09:55 AM
Skip1's Avatar
Not the brake wear sensor, that one actually goes to the brake and comes out of the hood just forward of the brake line.
I've never heard of a refrigerant over pressure switch, but suppose it's possible, the AC doesn't work right now, will be installing a new Griffith's system this summer.
Which light could such a thing activate?
Skip
2011 Cayenne S
Old 04-26-2014, 10:21 AM
wwest's Avatar
If it is a pressure switch, high probability of that, it opens the compressor clutch circuit if the system pressure rises to high.
Old 04-26-2014, 12:36 PM
wwest's Avatar
Like this....
Old 04-26-2014, 12:44 PM
Member 911 Anonymous
DRACO A5OG's Avatar
It looks like remainings of euro side maker socket.
'85 Carrera Targa
PCA/POC
Old 04-26-2014, 01:56 PM
'82 SC TL
canamfan's Avatar
I think Draco got it, check the passenger side/fender, wheel well area for another one to verify . A "peanut pinch" bulb should fit right in there by the looks of it & that's pretty much the location for that plug with rubber cap & tab.
76'S 1st Porsche white/can/can early rebuild (boo)
'84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1)
'87 Carrera cpe white/blue short flirt
'89 Anniv. sil/linen very pretty miss her
'88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Old 04-26-2014, 02:02 PM
kuehl's Avatar
You can tell by the number of wire terminals.
If Skip has a 1984 they did not use ac "pressure" switches.
The earlier 70' years may have had a ac "temperature" switch attached to the drier.
Temperature correlates with high side pressure.
Old 04-27-2014, 08:25 AM
wwest's Avatar
If Skip has a 1984 they did not use ac switches.
The truth will... OUT!
I'm going to record that as my favorite Kuehl post of all time...
Old 04-27-2014, 08:33 AM
kuehl's Avatar
Oh god.
Wwest is at it again, lol.
Old 04-27-2014, 08:39 AM
wwest's Avatar
Oh god.
The statement wasn't meant to be demeaning in any way, just a reflection, acknowledgement, of your store of A/C knowledge of which you do not always volunteer.
Old 04-27-2014, 08:53 AM
Skip1's Avatar
Interesting discussion :-). I checked the passenger side and it has the same connector. The car is a RoW German spec, but I assume that the fenders were changed at some point in its history as it doesn't have the side marker lights any more.
Love this forum - learned about AC and my connector at the same time. It is an '84.
Thanks a bunch.
Skip
2011 Cayenne S
Old 04-27-2014, 10:52 AM
