install of Alu rear window trim
On my 88 the rear window trim has been hacked up at some point in it's life. I have managed to track down new alu trim, but I know from messing about with the old stuff that if you bend it once, you will never get it flat and straight again.
Any tips on installing the new stuff? I searched about, but all I found is people running without it and removing it for painting etc... I have the parts, I'd like to use them. Could use some pointers on the install though. |
What?
The first step is to remove the window, put the old seal in the trash, get a new "Genuine Porsche" window seal.
Step 2: Place new rubber seal around glass. Step 3: Install aluminum trim into the seal. Step 4: Install the whole assembly into the car. You'll need some kind of cord, like grass trimmer cord to place in the groove to pull the seal over the body. You'll need a second set of hands to place pressure on the outside of the seal and trim while you pull the cord on the inside of the car.
________________________________________ Eric Hahl 85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD) 2015 981 Cayman S (Sold) 23 Outback Wilderness & 23 BMW R1250GS |
So the window has to come out in order to install this piece of trim!!?
Absolutely! no other way, but it's really not that difficult, just helps to have a friend to assist.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Schleprock
You do not want to be foolish and try to reuse the seal/gasket. Once its been used for many years, it takes a set and forms itself to however it's been compressed/squeezed into the window channel. So the point is, reusing an old seal is just asking for leaks IMO when it doesn't fit into the channel exactly how it was previously installed. To avoid breaking the window upon removal, it's often recommended to slice it with a utility knife (fresh blade installed) to relieve the grip of the seal.
Kevin L '86 Carrera "Larry" |
Question, is any glue involved here?
Serge |
What?
No glue required.
I have heard that (specially for the front window) to use glue?
PhD on Pending Projects
This should help...
I have this bookmarked for when it is time to do mine: Quote:
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
Bookmarked this as well. The seal I ordered last night from PP is listed as OEM, so assume it's close as can be to GENUINE. Kudos to jury for this excellent visual and writeup. Can't wait for the seal to arrive and give this a shot.
Tony |
The biggest PITA about this job are the rear defroster wires that run through the gasket.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Nightmare. I thought I'd just knock the new trim in, seems like this requires a glass removal and a fresh install. My existing trim is OK, just not correct and short in places. I think I'll keep the new parts on the shelf until I have nothing more pressing to attend to!
Yeah, I agree: if it's just for cosmetic reasons it's probably not worth the trouble. The aluminum trim can have small gaps and still do it's job. The main concern would be the condition of the seal.
Maybe confirm that the window in fact doesn't leak. The rear seat upholstery can soak up alot of water before it would ever manifest itself (typically wet carpet in the rear foot wells after a rainstorm). And as Uwanna indicated, don't even think about "just knocking the new trim in." |
