safe's Avatar
915 diff failure!
Has anyone seen something like this?
Happened during an auto-x start...
How would I prevent this in the future?
Magnus
Old 05-12-2014, 10:43 AM
Less horsepower ?
Old 05-12-2014, 10:51 AM
safe's Avatar
Less horsepower ?
That is out of the question!
Magnus
Old 05-12-2014, 10:57 AM
Straight shooter
Lapkritis's Avatar
Only way to minimize if you're going to reassemble with equivalent parts is to ensure when you start that the slack is taken out of the drive line and that you're using a sprung clutch disk.
Heel on the brake, toe on the gas and bring the clutch up where it just starts to push. Expect shorter clutch life but more life from the rest in play.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 05-12-2014, 11:01 AM
MBruns for President
JeremyD's Avatar
stock side plate?
Old 05-12-2014, 11:08 AM
safe's Avatar
Originally Posted by JeremyD View Post
stock side plate?
Yes, stock but rebuilt, 1977 mag case.
Would a stronger side plate help?
Engine has ~260 hp and ~300 nm.
Magnus
Old 05-12-2014, 11:12 AM
safe's Avatar
No more 4000 rpm and dumping the clutch?
The clutch is new for this year, springed but a much more grippy 6-puck disc. The stock clutch was slipping under load.
Magnus
Old 05-12-2014, 11:18 AM
JeremyD's Avatar
Yes,
When I was researching my 3.6 upgrade - people smarter than me recommended the following in order of importance:
1. Side billet plate - the stock plate allows too much movement in the bearing carriers - with allow the diff to twist - that's bad. Also while you switch out the side plate - also switch to the 930 version of the bearing carriers - they are more meaty.
2. LSD - you want a Limited slip - if you have one wheel driving (with sticky tires) you get more of that twist that I described above - that's bad.
3. The one piece main bearing plate - or snowman as some refer to it. Usually needs to be installed at a tear down.
4. Cooling - Keep your differential cool - even a small cooler (like the factory euro 915 cooler) can make a huge difference in operating temps - this is mostly for the track though = doubt it would make that much difference on an autocross course.
Old 05-12-2014, 11:55 AM
safe's Avatar
Yes,
All things I have planed for the 915 in my 69 coupe.
I do track this 77 targa a lot. Oil cooling would not be a bad thing, 2-3 hours of almost continuous track driving probably cook the box pretty good...
The car is so soft (conforming to the track) that I seldom has any wheel spin, so I skip lsd.
I'll try to get the box to my gearbox guy this week. He reinforces the side plate with a steel plate. That's how it was done in the 70s.
Magnus
Old 05-12-2014, 12:12 PM
scarceller's Avatar
Fit a G50 in?
Or use the older 930 4 speed?
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 05-12-2014, 12:27 PM
arrivederci's Avatar
Yes,
All great advice and exactly what I've heard. Also, I believe the factory cooler in #4 won't work with the upgraded side plates in #1. So you'd have to go an aftermarket route for cooling.
- '72 911T
- '81 911SC Euro
sjf911's Avatar
Wow, that is something else. Were you having a lot of wheel hop issues? I know I had a lot before putting in my LSD and that really cured it.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 05-12-2014, 01:08 PM
ganun's Avatar
The diff carrier broke along the spider gear pins, I don't think the side plate plays a role.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 05-12-2014, 01:31 PM
safe's Avatar
Some, when the traction was bad.
Magnus
Old 05-12-2014, 01:52 PM
gearhead
Seen it a few times...
It's a 37 year old part being used in motosports. In my experience auto-x is about second in abusiveness only to rally. Lots of shock loading in auto-x.
Hopefully you didn't take out your ring and pinion as well. However, no matter what, I would do a full tear down and make sure your case bearings are still all right.
Sidecovers are a nice upgrade but really won't do anything to prevent this. Nor will a cooler. In fact, many times I find that auto-x guys don't spend proper time warming up their gearbox. You know how they say that the most wear you put on your engine is when you start it? Most wear you put on the gearbox is the first 10-15 minutes until it's temperature goes up. I advise all auto-x racers to spend some time in the morning just tooling the car around the paddock getting the gear oil up to temp.
Get a new differential and you shouldn't have much to worry about. An LSD is nice because if you lift a wheel it keeps driving power to the ground. Downside for auto-x is it locks under braking. Gives a lot of corner entry push right when you are trying to rotate the car early.
TBDs are great for power on traction. They don't lock at all under braking. Downside is they go open if you lift a wheel. Also tend to be a fair bit less expensive than a salisbury style LSD.
PS. I do NOT use LSD and TBD interchangeably. Quiafe does. They say their TBD is an LSD. Not how I define these things from a technical standpoint. a Torsen design, or torque biasing differential is not an LSD in my book. Has no limit under zero traction. It goes open. That's not limited slip.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-12-2014, 02:06 PM
safe's Avatar
I agree that it can be abusive and that I'm probably guilty of little warm up....
I'm leaving the gearbox to a guy who has done rally 911s since the 60s, he'll know what to do.
I'm not sure I want an LSD for autox because of the push, maybe a TBD as you say, unfortunately the budget don't allow for that now.
Magnus
Old 05-12-2014, 11:19 PM
safe's Avatar
OK, the box is back from the builder and with reinforced bearing retainer and side plate.
But, it has a noise... Sort of an grinding noise, like: RRRR...........RRRR...........RRRR...........
The RRRR part a little like when you try to shift without depressing the clutch, but a lot less.
I hear it during coasting in neutral or with the clutch depressed (in any gear). I also hear it when I jack up the rear and turn both wheels at the same time, hopeless to say from what part of the transmission it originates.
Can it be a damage to the pinion or ring gear, how would that sound? The builder said he couldn't find any obvious damage.
Magnus
Old 05-26-2014, 06:05 AM
Geary's Avatar
I once went into a transaxle immediately after a nasty wheel hop episode, and the only damage I found was bent spider gear pins. I believe wheel hop is responsible for your broken diff body.
Old 05-26-2014, 08:28 AM
Straight shooter
Lapkritis's Avatar
Exactly what work was done? Loose lash, bad diff carrier bearings/races. Couple things come to mind as possibilities.
Old 05-26-2014, 08:48 AM
safe's Avatar
Basically the entire box was checked over, lash set and carried bearings was replaced.
Just talked to the builder. The pinion had minor (pinhead sized) damage that was polished away. He said to run it and see what happens, if it gets worse it does...
Magnus
Old 05-26-2014, 09:22 AM
