cycling has-been
3.2 intake rib/support delete?
These ribs are starting to annoy me.
Anyone ever grind them off? Do the serve any other purpose other than support the blower and act as a heat sink for the intake air? Thanks Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
I removed the base for the blower.
Never missed it....
cycling has-been
Now THAT's what I'm talking about.
Nice motor Rob. What year? Bill K
Thank you Bill.
Itīs a 3,2 ROW engine from 86. While you are in you could also remove the scars from casting between the intakes. |
Here's my intake manifold after several hours of prep and finishing - soon to be installed.
![]() Sherwood |
Looks familiar... great
![]() Have you already choosen a color? |
Caveman Hammer Mechanic
It's never too early for Jack and coke!
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
On another note, has anyone done a before dyno and extrude hone after dyno run series?
E-85 sippin drunk
Here is a 3.2L intake in Perma chrome (ceramic coating)... casting marks removed... but I kept the bracket you are inquiring about to mount my coils to....
[IMG] [/IMG]
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
E-85 sippin drunk
The real benefit comes from having the runners balanced to each other. Before ExtrudeHone process, they were 50 to 70CFM difference between all 6 runners (IIRC), and after the process, it was less than 5 CFM.... For my engine, I wanted it to be as balanced as possible, as much HP as I am looking to get out of it..... Brad
FWIW, I recorded some in-process deletion pics.
![]() I wonder if there's anything here I need? Oh well. ![]() Now it's a "lightweight" intake manifold. This is about 2/3 of the debris: ![]() Sherwood |
What were your plans for the support for that long tube that leads to the venturi gizmo, if you chop the bracket? Just leave the tube dangling? My understanding is that the tube can be eliminated entirely if you don't need the brake booster. I'm guessing you use a brake booster though...
cycling has-been
See post #2. The "y" junction is available at Home Depot or Lowe's.
You guys are all sick, and I like it.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
cycling has-been
I have no idea what you're talking about......
Which "y" junction? Isn't the arrangement in post #2 just the later venturi setup which doesn't have the same support arm?
