lespaul's Avatar
Drop engine with or without tranny?
Next weekend I plan to drop my engine and remove the 8 broken exhaust head studs on my '78 SC and check out the top end and clean up things. I am hoping to not get into the bottom end. My engine has 35,000 miles on it.
I understand I can drop the engine with or without dropping the transmission. Indeed I dropped the engine on my '73 without dropping the transmission.
What are the benefits/cons of dropping: a) with the transmission or b) without the transmission?
Brad
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 07-02-2014, 12:17 PM
1988 Carrera
shadowjack1's Avatar
It takes so much less time to drop them together. Much less hassle as well. I did the engine drop alone back in the 80's. To me it was a real PTA.
Old 07-02-2014, 12:22 PM
lespaul's Avatar
This makes sense. Getting that hex bolt off the starter is a PITA.
If the engine and tranny both are coming off:
1. Where is the balance point for my furniture dolly?
2. Does anyone have a list of instructions on how to do it? I have the 101 Porsche Projects book instructions but it does not involve dropping the transmission.
Brad
Old 07-02-2014, 12:27 PM
ROW '78 911 Targa
timmy2's Avatar
Balance point is just a little further back. The engine is the heavy part.
101 has a transmission removal section, just combine it with the engine removal section, eliminate duplicity and removing the starter.
No need to separate them either.
Old 07-02-2014, 12:36 PM
Engine and tranny together! Only way to go!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 07-02-2014, 12:49 PM
lespaul's Avatar
Thanks all. Another benefit is that I can clean the tranny easier when it is out.
However, I think I will separate them once out because will want to get the engine on an engine stand to make the work easier.
Brad
Old 07-02-2014, 12:51 PM
Engine drop using an engine dolly......
Brad,
I've been using this heavy duty home-made duty approx. 28" x 28" in dimension even after acquiring a hydraulic lift. I would never use a floor jack for an engine drop simply because of the balancing act and instability of the 500 lb. plus load. With the 500 lb. load sitting on a cart, getting it out under the car was easy and simple for an old guy with a back bad.
As you can see from the above pictures, the engine weight could hold the transmission on a cantilever position. For more stability, place wooden blocks between the transmission and the cart. If you are using the smaller and weaker wooden furniture dolly, you have to position the furniture dolly more closer to the transmission due to smaller loading area.
Whatever technique you decide to implement, first and foremost, is your safety. Take your time and work with someone if possible.
Tony
Old 07-02-2014, 01:03 PM
lespaul's Avatar
Thanks Tony. Good tips and nice job on your cart. I will have plenty of help - it is amazing how many people drool at the chance to help take an engine out of a 911.
BTW - how the heck did you get the rear of your car so high up?! Is it resting on jack stands near or on the standard side jacking points? Can't tell from the picture. When you are that high in the rear, do you have problems with the front bumper touching the ground?
Brad
Old 07-02-2014, 01:13 PM
Under the radar
Trackrash's Avatar
Tony,
Is that a crane you are using to lift the car? If so, could you show some pictures of how you are doing that?
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-02-2014, 01:18 PM
i think it's easier to leave the trans in the car. just slide the shift coupler off the end of the trans and let the trans hang. the only thing you have to watch on installation is that the release fork engages with the t/o bearing, by watching with a mirror and flashlight through the hole in the driver side top of the bellhousing. viewed from the top. then just get the angle of the engine the same as the bellhousing face and wiggle them together. you can eyeball or use a protractor. recheck the fork before bolting them up. easier by far to balance on a jack, too.
206 637 4071
Old 07-02-2014, 05:14 PM
I normally would not disagree with JW, except for this once. John has the benefit of doing 1000 engine drops by now. And he can do it blind folded with one hand tied behind his back. For anyone who is doing it the first time, and the next 10 times, the engine and tranny coming down together gives a chance see how the two fit and how they come apart without the need for flash light and mirror.
I am not a novice at dropping the 911 engine and I would still do it with the tranny. It does only take me 2 hours because I no longer stop to take notes and take pictures. And, I have all the necessary tools in one place.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-02-2014, 05:34 PM
Retired Member
Brian 162's Avatar
I used a piece of plywood and a pallet truck to remove and install the engine/transmission. On installing I used a jack at the front of the transmission to get a better angle for the shift rod to get into the tunnel.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 07-02-2014, 05:38 PM
Registered Loser
I have a cart too if you want Russ to pick that up as well. It is very heavy though. For us newbies, drop the whole engine and trans.
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320
Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180
Old 07-02-2014, 05:46 PM
otto_kretschmer's Avatar
with
it's a piece of cake taking out both
Old 07-02-2014, 06:52 PM
balance point is somewhere between the sump plate and the engine/tranny split
it's been a few years since I did my clutch but let me get the instructions out of the round file in my head
jack up back of car really high
detach battery leads
take out shift linkage screw
drain oil
remove/detach oil lines
remove harness connection on driver side of engine compartment
remove clutch cable
remove throttle cable
remove cv joints on tranny
remove cables to starter (should be 2? one big to the starter and one small to the solenoid?)
optional: remove muffler (it may be easier to get out with the muffler off, depending how high you jack the car up, I remember taking it off)
place jack under engine/tranny at balance point
remove back engine mount bolts
remove front tranny mount bolts
drop engine
I did it by myself but if you have help from a friend who is not mechanically challenged, it may go easier
Old 07-02-2014, 07:04 PM
When the motor/trans drop or reinstallation is done in a shop with a twin post lift, is the engine/trans put on a table of sorts and kept still, with the lift being used to raise or lower the chassis/car? Thanks, John
Old 07-02-2014, 08:05 PM
PrimeMvr's Avatar
That's how I do it with my scissor lift, using an ATV jack to hold the engine and a floor jack under the trans to manipulate the angle. Easy.
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD
10 997.2 Cab - Speed Yellow
83 SC Cab - Guards Red [SOLD]
17 NSX - Nouvelle Blue
Old 07-02-2014, 08:26 PM
ROW '78 911 Targa
timmy2's Avatar
I use the pelican floor jack adapter and my scissor lift.
Lift a bit with the lift, fit the jack and adapter under the engine, remove 4 mounting bolts, lower the jack a bit and tilt.
Lift the car and roll engine and tranny out.
Everything else disconnected first. One man under 2 hours.
Old 07-02-2014, 08:49 PM
Hmmm, good idea . I'm dropping my engine this weekend and I can borrow a pallet jack from work.
Old 07-02-2014, 10:24 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
My way:
Drain oil and disconnect everything except 4 mounting bolts (2 engine, 2 tranny)
Floor jack under the engine case with dolly in place under engine/tranny
Lift rear with floor jack, take rear wheels off and lower car so that HE/engine rests on the dolly
Remove 4 bolts (2 engine, 2 tranny)
Use axle stands under torsion tubes and lift pads on door sills
Lift car with floor jack(s) acting on lift pads and raise axle stands as safety
Place wheels under car as safety on either side in case axle stands and floor jacks fail
With this method the engine/tranny never leaves ground level and is resting on the furniture dolly. Once the cars rear is high enough you can pull the engine/tranny package out. I don't even have to remove the rear valance. This can be done safely, as a one-man operation and take about 2h if you don't slack.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 07-02-2014, 11:27 PM
