86 ssinit's Avatar
Another wiring question
Does anyone know what this plug is for? It is on the bottom right below my fuse panel. It has 7wires. I have a 86 targa. I installed the headlight relays and this was on the lower front screw where you attach the relays.
1986 Porsche 911 Targa
1983 911 sc
2015 WRX
Old 07-27-2014, 04:43 PM
86 ssinit's Avatar
Bump
Old 07-28-2014, 04:24 AM
Discseven's Avatar
I don't have the answer "86," but I'll post my '80 fuse panel for you --- perhaps there is some value in this reference:
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-28-2014, 07:06 AM
ROW '78 911 Targa
timmy2's Avatar
Something a PO added?
Aftermarket alarm?
I don't think it is factory.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-28-2014, 09:45 AM
scarceller's Avatar
That connector is stock, I have a pic showing that connector in the factory manual. Still looking to see what it's for but it's defiantly stock.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 07-28-2014, 10:04 AM
ROW '78 911 Targa
timmy2's Avatar
If you have the factory manual, then just follow the wires to where they go.
Old 07-28-2014, 10:33 AM
scarceller's Avatar
I see the connector in an actual picture of the fuse block. It does not tell me what the connector is for.
Sal
1964 356SC (SOLD)
Old 07-28-2014, 10:38 AM
scarceller's Avatar
Can you trace any of the wires to a specific fuse? That may help narrow down the circuitry.
Sal
1964 356SC (SOLD)
Old 07-28-2014, 11:12 AM
86 ssinit's Avatar
Thanks for the help. I have an 83 sc and it's not on it. Think it's factory and I thought it might be common and someone would have a quick answer. Will check where the wires go. Car does not have an alarm system.
1983 911 sc
2015 WRX
Old 07-28-2014, 11:34 AM
scarceller's Avatar
I have a 84 cab and it does NOT have that connector. So what features where added in 85-86? I do have factory alarm. No Power seats.
You could just unplug it to see what does not work.
Sal
1964 356SC (SOLD)
Old 07-28-2014, 11:49 AM
scarceller's Avatar
Power seats where added in 85 so maybe it's for that option?
Sal
1964 356SC (SOLD)
Old 07-28-2014, 11:52 AM
86 ssinit's Avatar
Ok pulled plug seats still work but the open door buzzer was dead. Have to see what else is on with them.
1983 911 sc
2015 WRX
Old 07-28-2014, 12:06 PM
TheSt|G's Avatar
Pretty sure my '85 with power seats does not have that item.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 07-28-2014, 12:12 PM
86 ssinit's Avatar
Not power seats they worked after I separated the plug. But another questions on power seats do your power seats work when the key is out of the ignition?? Mine do. I thought that was strange.
1983 911 sc
2015 WRX
Old 07-28-2014, 01:23 PM
scarceller's Avatar
Just looked at the power seat schematic for 86-89 cars and that is correct, power seats have power at all times. Power comes from fuse #2 in fuse block #3 located in the front trunk.
Sal
1964 356SC (SOLD)
Old 07-29-2014, 05:36 AM
gwinnch's Avatar
Can't find that plug anywhere around or behind the fuse block in my Targa production date 04/85. It might be in the nest of wires that disappears under the fuel filler line, but, as they are undisturbed, I did not pull mine out-but I don't think a plug that big is hiding under mine. Does that connector have any numbers on it to google? Have you traced any of the wires to anything identifiable? Quite a few of you will recognize the mods to my panel recommended by "86 911 Targa". I'm very happy with those, thanks again Gerry.
1985 911 Targa
2001 996 C2
2009 997 C4S
Old 07-30-2014, 07:34 AM
scarceller's Avatar
I suspect that this connector was added in the 86 model year. I also don't have it in my 84.
Sal
1964 356SC (SOLD)
Old 07-30-2014, 07:38 AM
gwinnch's Avatar
Found Gerry's Fog light comments in the attached thread. You can clearly see the top of the same plug on his 86 before he added his head light relay. Look through some of his other posts, there may be more info.
Fog Light Help
1985 911 Targa
2001 996 C2
2009 997 C4S
Old 07-30-2014, 08:04 AM
