71 911E cold start problem
Help! I've spent hours trying to diagnose my cold start problem. I have taken the cold start solenoid off the top of the fuel filter and bench tested it and it works fine when I give it 12 volts. I tried to test the wire that plugs into it and I only show a little more than 1 volt. I made sure the ground wire is bolted on to the fuel filter and the connection is clean. Not sure where To go from here? Thanks for any help
Mark |
Max Sluiter
Well, there is a thermo-time switch that tells it when the engine is cold. I'm not familiar with the wiring layout but I guess that is a start.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Thread Tools | |
Rate This Thread | |
