SWB adjustable spring plates and alignment
I began a new project this weekend; I'm modifying my shortened 911SC spring plates to have a screw adjustor like Sway Away no longer makes. I'm also beginning a four wheel alignment and corner balance using the corner scales and simple string alignment aid I made and will be marketing shortly; more on that later.
I first removed rear shocks and installed my height adjusting rods: ![]() I also disconnected my front sway bar drop links and connected them to the brackets on my inner wheel well: ![]() I adjusted rear ride height while supporting front cross member to avoid corner weight bias: ![]() Made a CAD drawing and templates for modifying the spring plates: ![]() And: ![]() Photo of brackets aligned on spring plates ready for welding: ![]() That's all for today.
Paul Abbott Weber service specialist www.PerformanceOriented.com |
Nice springplates! I love DIY
Roland 930 Turbo '81 Too many modifications to list |
Project Addicted
LOVE these on my '66 912.
Took some grinding of the screw mount and the lug it presses on to make 205's not rub. ![]() I can send pic of the grinding if needed. I can also measure it too.
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
Hi Jon,
I think I'm good, I checked tire clearance before I removed for the surgery. Running 225/50-15's on 7Rs with spacers.
Banned
Paul how did these finish up?
I installed and adjusted my car using these just fine. I need to make one more iteration in ride height that is beyond the range of adjustment but haven't gotten there yet.
BTW how are you using the height adjust rods
I used the rigid links to adjust ride height and alignment and then installed t-bars and adjusted to just take the load ff the links.
I made the links for use in assembly and other tasks during my build as a convenience to hold the car at ride height while working on it...this is primarily why I had the links in the first place.
Project Addicted
Paul, can you provide some details for your mod??
Thickness of ne blocks? Bolt size and threads? A PDF of the drawing of the plate for modifications?? I know it's asking a lot be we want to perform this mod on our project car and love the DIY aspect.
Contact me via m business email and I can get drawings to you. Performance Oriented
Paul - those ride height links look like just the thing for locking the suspension and figuring out the center of gravity.
