heater flapper box cable nut problem
Hi Guys,
I'm trying to replace the heater cable in my 3.2 carrera.
My problem is, the nut used to fasten the cable to the flapper box spins freely. It seems that the bolt which the nut screws onto should be fixed to the back of the box, however it spins freely together with the nut.
Any ideas besides removing the flapper box (seems access will be difficult)?
Thanks for your help!
Adam
_____________________
'73 RSR Interpretation
Old 08-27-2014, 09:10 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeah, this one sucks, I used a needle nose vice grip to hold the nut in place while I tighten the bolt.
'85 Carrera Targa
PCA/POC
Old 08-27-2014, 09:45 PM
Awesome, I did try this at the time with normal vice grips.
I'll find some needle nose and give it another go.
Thanks!
Old 08-27-2014, 10:40 PM
douglas bray's Avatar
I used a ratcheting flex head box wrench to snake up in there. It's the same size as the nut.
Old 08-27-2014, 10:58 PM
Brew Master
cabmandone's Avatar
I used a end wrench the same size as the nut on the bolt.
Old 08-28-2014, 04:20 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
M4, if I remember. 7mm heads on both the nut and bolt.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 08-28-2014, 07:45 AM
Calnan's Avatar
StayGold -
Are you replacing the cable from the bottom red slider on your dash unit to the front compartment flapper / control box? If so, I may check in with you via PM if you don't mind - I'm struggling a bit with this same project.
Thanks -
Mike
1989 Carrera Coupe - 25th Anniv Edition - SOLD
1987 Carrera Coupe - Black/Black - SOLD
2010 Cayman - Dark Blue Metallic/ Black - SOLD
2016 Cayman GTS - GT Silver/Black - What a ride...!
Old 08-28-2014, 11:17 AM
steely's Avatar
go slow - if it is the small one I am thinking of with the hole in the side to accommodate the cable wire, it will not take much torque. Ask me how I know.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 08-28-2014, 03:42 PM
